67 cutlass 455 canton oilpan fitment issues
Old Nov 2, 2025 | 09:03 AM
retro1977's Avatar
Installing a 455 based 495 in a 67 supreme that is a total drivetrain rebuild, I bought new 2261 mounts verified I have correct sbo frame mounts and pan is laying on crossmember and cross shaft of the steering and can’t get both bolts thru mounts. Has anyone had this issue with the canton oilpan?
Old Nov 2, 2025 | 11:23 AM
fleming442's Avatar
I have a Canton in my 468 67, and there's about an inch underneath it.
Old Nov 2, 2025 | 11:56 AM
retro1977's Avatar
Thanks fleming442, I even went down and picked up a set of other mounts thinking maybe I had bbo frame pads and it wouldn’t even sit down on frame pads any ideas what it could possibly be?
Old Nov 2, 2025 | 03:32 PM
fleming442's Avatar
Wish I could help. Mine really isn't a good example. I've got Smittys solid mounts from way back, a front plate on brackets I made, and a crooked frame. BUT, it is proof that it will work, as i have a drop base air cleaner on a Holley Street Dominator and the hood shuts.
Old Nov 2, 2025 | 03:46 PM
retro1977's Avatar
Yes sir went thru your post good looking car. I seen the motor plate and also the air cleaner.
Here is the project..
Old Nov 3, 2025 | 08:01 AM
fleming442's Avatar
Dig it, good looking ride!
Old Nov 3, 2025 | 10:37 AM
retro1977's Avatar
Thank you sir should be a fun project.
Old Nov 4, 2025 | 07:51 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Mine fit fine in my 70 Cutlass. I wasn't impressed with how warped it was, otherwise plenty of room, small block mounts and frame pads with my Olds 358 build.
Old Nov 13, 2025 | 08:13 PM
retro1977's Avatar
Thanks everyone I think I got it figured out
Bigdibbs88
Jan 20, 2025 09:15 AM
steverw
Feb 22, 2013 06:27 AM
diesel olds
Feb 13, 2013 07:43 AM
gthmcty1
Jul 23, 2009 02:50 PM
gthmcty1
Feb 26, 2009 06:21 PM
