67 cutlass 455 engine mounts
Old Feb 12, 2013 | 06:24 PM
diesel olds's Avatar
doing a frame off on a 67 cutlass that came with a 455. the engine sits to high in the frame and air cleaner clearence is an issue what frame mounts/ engine mounts should I use it currently has 330 mounts and i understand the 455 is a taller block im sure someone else has run into this
Old Feb 12, 2013 | 08:51 PM
lemoldsnut's Avatar
A big block does sit high in that car. If you had a stock air cleaner it sits way low on the intake. That is what it takes to make it fit. If you use an aftermarket intake it will sit too high and hit the hood.
Old Feb 13, 2013 | 07:43 AM
I use something similar to this however I have a BBC in mine. This will work on a rochester or a holley, not on an edelbrock carb.
http://www.ebay.com/itm/65-67-Corvet...sories&vxp=mtr
JCMC64
May 26, 2017 10:04 AM
gunmetal71
Jul 10, 2015 11:02 AM
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
flatoz
Mar 15, 2009 02:03 PM
