1967 Cutlass Supreme Holiday Coupe
Old July 5th, 2021, 10:48 AM
  #81
babailey's Avatar
I prepped and painted the Flaming River Tilt steering column.
I hope to get it installed some evening this week.
babailey is offline
Old September 3rd, 2021, 03:44 PM
  #82
babailey's Avatar
I’m looking at a top end kit from oldsrocketparts.com (https://oldsrocketparts.com/index.ph...-will-fit-330/) has anyone used this on a 330 before? If so, was it a good experience?
Thanks!
babailey is offline
Old September 3rd, 2021, 03:51 PM
  #83
72 Olds CS
RetroRanger's Avatar
No experience w them but who is oldsrocket parts?
RetroRanger is offline
Old September 17th, 2021, 07:32 PM
  #84
babailey's Avatar
I rebuilt the rear end again and I, apparently, did a much better job this time. The new posi makes a little noise while I’m turning but no nasty sounds anymore and it is very quiet when I am driving straight. I hope this is the last rear end I ever have to rebuild!
babailey is offline
Old October 10th, 2021, 04:34 PM
  #85
babailey's Avatar
Engine rebuild parts collection has begun.
babailey is offline
Old November 14th, 2021, 02:21 PM
  #86
babailey's Avatar
My original antenna broke off ( I was not careful removing the car cover). I’m about to take the fenders off so I can get to the motor more easily, is there room in the fender for a power antenna?
Thanks!
babailey is offline
Old November 14th, 2021, 05:07 PM
  #87
Holden/Olds/Audi/Porsche
BOGAN's Avatar
great thread. miss my 66
BOGAN is offline
Old November 23rd, 2021, 06:02 PM
  #88
babailey's Avatar
Sidetracked
My old fire pit finally collapsed. I’m building an new one from an LP gas tank head
babailey is offline
Old November 29th, 2021, 06:39 AM
  #89
babailey's Avatar
Sidetrack Project Complete…..
My welding training project is done. I learned a lot of ways to weld poorly, but but the end of the project I was starting to make descent welds.
babailey is offline
Old December 5th, 2021, 05:44 PM
  #90
babailey's Avatar
I’ve moved the Cutlass back into the garage to start the trans swap and some engine work. I have the 200-R4 and new torque converter ready to go in. I’m a bit worried about the throttle cable/kick down work that is required but I think I am prepared. I will only be doing minor engine work right now as I can not get the parts I want (I really want the aluminum Edlebrock top-end, cam, lifters, heads, I take, and probable EFI) but most of those parts are unavailable at the moment and I keep hearing later and later availability dates. So, I need to change the valve seals as the old ones are leaking like crazy. I hope to do this with the engine in the car and the heads bolted in place ( this rebuild has very few miles on it but it sat for 5 years which I think must have caused the valve seals to fail).
so, with the wife’s car out in the driveway and the Cutlass in the garage, I started looking at things more closely. First off, I seem to have displaced some squirrels…..
LOL!
babailey is offline
Old December 12th, 2021, 03:56 PM
  #91
babailey's Avatar
Christmas came early…..
babailey is offline
Old January 30th, 2022, 09:49 AM
  #92
babailey's Avatar
Ok, I know this will cause some people heartburn, but I am building a resto-mod and I’ve decided to lean heavier on the mod side. I’m thinking about purchasing a crate 383 stroker motor.I already have a freshly rebuilt 200R4. Is there anyone out there interested in the original HO 330 and 2sp trans with the working switch pitch torque converter?
babailey is offline
Old August 29th, 2022, 03:19 PM
  #93
babailey's Avatar
Her is how I spent my weekend…..
Here is what is going in its place…..
l have a ton of cleanup and painting to do before I can install the new engine and trans!
babailey is offline
Old November 22nd, 2023, 05:22 PM
  #94
babailey's Avatar
The motor and trans ar finally in and the car is running. I’ve made a few short trips around the neighborhood with the open headers and i love the sound (I suspect my neighbors are not as thrilled).
I’ had a terrible time getting the trans dipstick, oil dipstick, and headers in place since I left those off until after the motor and trans were stabbed back in place.
Headers in particular are very difficult to bolt up tight and leave very little room for spark plugs. I also had to fab an oil dip stick and dip stick tube to work properly with my motor and my car around those headers.
I finally got everything buttoned up, lights reinstalled, an some wiring repairs/cleanup done. I think I am ready to drive her to the exhaust shop and have the electric cutouts installed and the rest of the exhaust built (I hope they are open Friday after Thanksgiving).
Here is a shot of the grandson enjoying the car!
It doesn’t get much better than that!
babailey is offline
Alex Cat
October 17th, 2019 01:39 PM
juliusz3
February 27th, 2018 03:08 PM
Bamfer
November 6th, 2012 06:17 PM
oldolds88
May 26th, 2012 09:22 AM
2blu442
May 1st, 2011 07:29 AM
Quick Reply: 1967 Cutlass Supreme Holiday Coupe
