100% Led now !
100% Led now !
So spent the last two weekends finishing up my LED change over including Sequential Tail light panels. Here is the finished product. Sorry Video on cell phone had issues with the LED brightness.
Link to you tube video:
Sure Brian, Happy to share. The Tail lights are Easyperformance.com I liked these because they can be easily swapped back to stuck bulbs for OCA or AACA judging if needed. I ran the sequential operation via a separate wire which need to be tied to an ignition wire source. I did a quick connect terminal in the housing to handle that issue. The side marker lights are from Superbrightleds.com and I ordered them in red and amber. The front turn signals were the biggest issue since I went through three sets of LED lights Sylvania and Veno. The fit in the socket but do not fit into the twist lock. I finally found a set on Ebay the worked perfectly and had no issue with the lenses. Here is the link for them and the nice thing is they are 100% waterproof and half the price of the others. they are 1157's just to let you know. Here is the link for them.
https://www.ebay.com/itm/Bevinsee-11...x/193512451180.
Thanks 1Restorick.
So far everything is great engine wise it's a little beast. The only issue is a shelled out $375 to have my date coded Rochester 4BBL cleand and rebuilt. The carb shop didn't do something right since the engine builder couldn't get it to dial in with the engine. I waited 5 months for him to do something with it and nothing ever was. So now I'm in between trying to get it corrected and out the money that was paid for the carb service !
