3.5 blues
Old Oct 9, 2011 | 08:09 AM
pogo69's Avatar
morgan
3.5 blues
1999 intrigue 3.5 head gasket... garage says head is leaking(can feel surging from heater hose going to engine and making a poping sound from inside car...overheats) question.... can the rear head be replaced WITHOUT GETTING UNDER CAR...i'm wondering about how exhaust manifold comes off and i am somewhat physically impared(cant really get under car)...so can head be removed working entirely from top??? thanks a lot
Old Oct 11, 2011 | 09:48 AM
pogo69's Avatar
morgan
any help with my question?? (can rear head gasket be romoved from working under hood only especially the exhaust manifold removal)
thanks, pogo
Old Nov 18, 2011 | 04:45 PM
DJS70cutlass's Avatar
thanks, pogo
No and No. That 3.5 v6 is one of GM's biggest failures. That rear manifold includes the pipe that goes to the front head, and for that reason it cannot be removed without first pulling the trans. ASE certified mechanic with 15+ years experience here, book time is around 10hrs. Thats not including the head gasket change.
IMHO, the cars not worth fixing.
Old Nov 18, 2011 | 05:58 PM
Lady72nRob71's Avatar
Ouch...
Old Nov 18, 2011 | 08:55 PM
BIGJERR's Avatar
I bleed Oldsmobile
I have heard the 3.5 was a POS but my 99 Intrigue is 200 miles away from 200K with no engine problems other than normall stuff,Injector cleaning,AC clutch,Brakes rotors,Radiator & some sort of pressure valve and tune ups,It does use oil from what I'am guessing is valve seals but over all its been one of the best cars I have owned..........Did I just get lucky?
Old Nov 19, 2011 | 05:23 AM
In a word yes.
As with any engine, regular oil changes and routine maintence is key. And as a neglected engine, the 3.5 WILL find a very expensive way to fail. The op's motor probably got ran with no coolant a few too many times and warped a head or two.
Old Nov 22, 2011 | 07:05 AM
pogo69's Avatar
morgan
***update on my 99 intrigue****
here is in update and possibly a tip for others...when the garage diagnosed my car with head gasket failure due to overheating and a thumping noise from hoses(they said combustion gases mixing in with coolant causing loud poping noise from heater hoses)........ well i was upset and somewhat in disbelief, and i decided just for the heck of it to replace the 39.00 dollar thermostat...SURE ENOUGH...car now runs as before no overheat no poping noise temp gauge between 1/4 - 1/2 GARAGES GRRRRRRRR!!!! wanted to charge me thousands for a new engine rebuild all for a 40.00 dollar part...........thanks for replies
Old Nov 22, 2011 | 07:56 AM
Great news! Looks like you are now the lucky one!
I remember my neighbor had an O/H issue with a Taurus long ago. Shop replaced head gaskets, radiator, and thermostat but it never helped. He had me look at it and the one of the cooling fan wires was melted and that fan was locked up. Stupid shop never checked BOTH fans. I replaced the fan and he lived happily ever after.
Incompetant shops - geez...
Old Nov 22, 2011 | 10:35 AM
Rocketbrian's Avatar
Perhaps the 3.5 is expensive to fix, but I must say my 2002 Intrigue has been with out a doubt the best car I have ever owned. The only criticisms of the engine would be it would be hard to work on because of the wide cylinder heads on a 90 degree V6 design and its lack of bottom end torque. But it sounds and acts very refined, smooth and loves to rev. As a bonus it is great on fuel. Other than oil changes, I haven't turned a wrench on it. I have always used Mobil 1 and changed the oil based on the indicator light.
My only problems have been an A/C condensor, and typical W body stuff like an upper strut mount and a front control arm bushing. The original rotors lasted 8 years. I plan on keeping it several more years. It looks and works like the day I bought it; if only Olds was still around I'd buy another.
When I need a torque rush I just hop in my SX for relief.
Old Nov 23, 2011 | 07:09 AM
The 3.5 is a good engine as long as its maintained. I don't understand why shops don't do a thorough diagnosis. I guess its easier to baffel with BS than dazzle with brilliance!
Old Nov 23, 2011 | 04:04 PM
I do.
Doing a full diagnosis on a car with the 3.5 is probably going to be a waste of time. Most times it just ends with us giving the customers money back after spending a week trying to fix their car. That not very profitable from a buisness standpoint, so they'll just give to the worst case senario to get you out the door and get another car in that they can make money on.
It may not be right, but its reality in the industry these days.
Old Nov 23, 2011 | 04:23 PM
If a shop does not feel like messing with it they ought to say so up front!!! I have a few friends with smaller private shops that are very reputable that thrive on that kind of business.
I work at a car dealership, and am very familiar with whats profitable and whats not! Believe it or not we'd refer him to someone else!
Driftr
Jun 24, 2011 09:39 AM
wolfman98
Jul 28, 2009 08:47 AM
chris weber
Mar 19, 2008 07:51 PM
GothamCity
Oct 19, 2007 01:27 PM
Ranzan
Mar 19, 2007 02:27 PM
