Steering wheel center removal on a '65?
Old Aug 16, 2012 | 01:45 AM
at3reg98's Avatar
New 2 Olds
Can't remember if I posted this in another section or not. Anyway is there a trick to getting the center metal piece off the steering wheel on a mid 60's F-85? I removed the two screws but it doesn't budge at all and I don't want to bend it prying and pulling. Does the center hub need to come off first or something? Even that doesn't really move. I need to get the wheel off to tighten up the signal lever and shifter bowl.
Old Aug 16, 2012 | 06:35 AM
copper128's Avatar
Lt. Buzzkill (ret.)
If it's like my '67s, the center ornament is held on with spring tabs and just pulls off. Grab it around the sides and rock it a bit to loosen it, then give it a good yank straight out.
Old Aug 16, 2012 | 08:23 AM
at3reg98's Avatar
New 2 Olds
Hmm will try that. I'm on needles and pins because that metal piece is anodized aluminum and I know how easily that scratches.
Old Aug 16, 2012 | 08:29 AM
66400's Avatar
The round center cap twists off counter clock-wise, then you'll have 3 screws to remove the horn bar.
Henry.
Old Aug 16, 2012 | 09:43 AM
RAMBOW's Avatar
Ben
it has 3 tabs that lock it in place, as mentioned twist 1/4 turn, then it should pull straight out.
Holiday 98
Sep 23, 2012 07:26 PM
rroth01
Sep 1, 2011 07:37 AM
ghostrider
Jan 10, 2010 06:10 AM
Jamesbo
Jul 20, 2009 02:33 AM
markowyo
Oct 29, 2007 06:40 PM
