Wet Carpets - 1969 442
Old May 20th, 2020, 09:58 PM
hankr107's Avatar
Wet Carpets. I encountered some rain whilst enjoying the Olds this past spring and I found the carpets were soaked. After the skies cleared and the interior came out. Enlisting the missus and a garden hose, the leaks turned out to be poorly sealed kick panel vents and a missing antenna grommet. A .39 cent grommet and a couple of sticks of 3M strip caulk was all it took. Cleaned out the inner fender wells from within the vent area as it was full of leaves and debre.
Before putting the interior back together, I pulled the “wall to wall” aftermarket sound deadening material put in by the previous owner as it had trapped some water. Prepped and cleaned all the floor pan surfaces and coated it all with with Por15, reapplied new deadening material and installed new carpet set.
New seals, new carpet, new car smell!
hankr107 is offline
Old May 20th, 2020, 10:36 PM
hankr107's Avatar
The trunk also leaked, enter the missus and the garden hose again... Leaking at three different spots... the body seams forward of the trunk lid, the convertible gutter and trunk weather strip.
The body seams got a refresh of seam sealer, repaired the crack in the gutter and glued down the weatherstrip. Now its almost water tight. Ha.
hankr107 is offline
Old May 21st, 2020, 04:22 AM
Good job. Nothing worse than wet rotting smelly putrid debris baking inside of a car.
Vintage Chief is online now
Old May 21st, 2020, 11:19 AM
Guy Fillinger's Avatar
You should thank your lucky stars that your wife let you back out of the trunk!!!
Guy Fillinger is offline
Old May 21st, 2020, 11:27 AM
hankr107's Avatar
Thumbs up
For sure. Fortunately, it hadn't hit putrid...ha, just a bit humid.
hankr107 is offline
Old May 21st, 2020, 11:32 AM
hankr107's Avatar
lol. There was a moment, albeit brief... but yes, I do, count my lucky starts every day she lets me out, period. ha
hankr107 is offline
Old May 21st, 2020, 11:40 AM
We are 12 weeks into self-isolation and it is really upsetting me to witness Lori (my wife) standing at the living room window gazing aimlessly into space with tears running down her cheeks.
It breaks my heart to see her like this. I have thought very hard about how I can cheer her up. I have even considered letting her in - but rules are rules.
Old May 25th, 2020, 05:31 PM
hankr107's Avatar
lol
hankr107 is offline
troyd
April 8th, 2018 05:52 AM
mattking
October 13th, 2016 11:44 AM
70sdream
May 16th, 2016 05:47 AM
cheynemitt
April 30th, 2016 08:34 PM
jamac
February 27th, 2015 08:48 AM
Quick Reply: Wet Carpets - 1969 442
