Wing window seal
Old June 13th, 2019, 08:17 AM
Louise72's Avatar
Wing window seal
Hello all!
I have asked only a few questions during my time here.
My current issue, after washing my 72 I noticed on the inside of my quarter windows/wing windows that water was coming in along the bottom middle by the hinge.
Pulled the window out and the seal was crumbling to the lightest touch.
What options are there to reseal the windows? Is there a kit?
Attempted a search on the electronic-bay and only yielded results for 2 door post model cars.
Unsure if they would fit.
Has anyone else had this issue? What did you do? What options do I have?
Many thanks,
-Matt
Louise72 is offline
Old June 13th, 2019, 09:04 AM
Gary
VC455's Avatar
Hi Matt.
Assuming you have a more-door Cutlass in the 1968 to 1972 range... If so, the wing window is taller than on a 2-door. I don't know of anyone who reproduces this yet. I say yet, because 4-doors are becoming more popular as the prices of 2-doors continue to escalate.
You could buy a 2-door kit, but you have to stretch the rubber to fit and that leaves some gaps that need to be filled with a flexible sealer. I used black Shoe Goop on mine.
VC455 is offline
Old June 26th, 2019, 06:23 AM
Noel Anderson's Avatar
Hi Matt,
I just got off the phone with Steele Rubber Products on reproducing the vent window seal for my 1969 Cutlass Supreme Holliday Sedan. The seal would be the same for all 1968 through 1970 GM A body four door hardtops. Unfortunately they said the mold would be $30,000.00 and unless there was more demand they could not afford to reproduce it. Luckily my seals probably can hold out a little longer. As for your car being a 1972 it might be more popular so they might want to reproduce it. I would give them a call if you have a chance, I was talking to Eddie.
Good luck with your project,
Noel
Noel Anderson is offline
Old December 15th, 2019, 06:00 PM
oldsrock's Avatar
Check out Einstyn.com. He makes a bunch of stuff for wagons and has the correct vent window seals. A Wagon is the same as 4 door from the front doors forwsrd. I have bought some other parts from him for my 68 Vista and it was good quality.
oldsrock is offline
Old December 16th, 2019, 05:25 AM
Thanks Oldsrock, his site shows them for the wagon. I will try to verify they are the same before ordering. I believe there were 4 different vent window styles that year.
Noel
Old December 16th, 2019, 05:28 AM
Noel
cublex
October 12th, 2018 06:49 AM
stevengerard
September 20th, 2017 09:36 AM
1966Oldsmobile
January 21st, 2013 09:36 AM
matchek
September 27th, 2012 09:46 AM
1965cutlassragtop
May 8th, 2012 01:00 PM
Quick Reply: Wing window seal
