Kick Panels Cutlass 1966
Old December 27th, 2017, 12:36 PM
olds77's Avatar
Hello
Looking after kick panels for my 66 Cutlass, the ones I removed had the vent flaps but when I look at OPGI.com page they are without the flaps. But if I look for panels for a 67 Cutlass at the same dealer I could buy them with the flaps? Should the 66 have these vent flaps or not? I guess the 67 will fit since the body is the same. Just wonder since they not list the panels with flaps for the 66. Someone out there who knows?
olds77 is offline
Old December 27th, 2017, 01:01 PM
Originally Posted by olds77
Hello
1964-67 A-body kick panels are the same. There are two styles from the factory. Those with vents were used in non-A/C cars and those without vents were used in A/C cars. You can also get aftermarket versions that have speakers.
Do not use use the catalog of an aftermarket vendor as a source of information like this - they are frequently incorrect.
joe_padavano is offline
Old December 27th, 2017, 03:59 PM
66-3X2 442's Avatar
I'm pretty sure that 67 had the vent pull handles made into the panel and the 64-66 had a separate handle that attached to the bottom of the dash.
The 66's with A/C I have seen used the vent style panel with a block off plate over the cowl hole. I'm not sure about 64/65 but I'm sure about 66.
66-3X2 442 is online now
ThePackRat
January 2nd, 2014 08:52 PM
Bobac455
September 7th, 2010 11:47 AM
rickbmac
April 7th, 2010 06:51 PM
Quick Reply: Kick Panels Cutlass 1966
