very small question on bench seat hardware
Guys, I have the bench seat arrangement in my 70 Supreme Conv., and the right side "end cap" or retainer is missing( at the pivot point from the seat back to the seat base). The previous owner installed a semi-fitting "c" pin around the seat "rod or shaft". I need to know if :
a) anyone has a spare one for $$$
b) where can I get one, short of rummaging through a yard
c) if I recreate one, anyone know what I would need as far as diameter, screw on? hammer on( I suspect)?, etc
Thanks for any light y'all can shed on this
Mark
Mark
Be seated
I have seen those end caps at the hardware store ( around here it's Home Hardware) if you have a Tractor Supply Chain store check them out also. it is sort of like a wheel to axle retainer for utility carts, wagons, shopping carts, etc.. Sorry, I can't find a part number for you.. but there might be a bushel of them at Seven Springs next week..
Rare item in perfect shape...They are not reproduced.
I researched using the bucket ones, but they are the wrong size.
Since they are a "one use" item, they are usually damaged in removal and very hard to reuse. What I ended up doing is having the uphol. shop using a plain push-on lock ring to hold the seat, then glued the chrome cap over the top as the top looked okay (lock tabs were broke).
As mentioned already, look at axle caps at the hardware stores. The ones at Lowes are ugly, but you might find some that look nice elsewhere. Try Ace or Elliott's if in your area.
Now why doesn't TSC sell tractor parts? I went in looking for some tractor tire tubes and they looked at me like I had two heads...
I cannot figure that part out for the life of me; they should change the store name.
Tubing
You are going to the wrong store!! Alliston TSC has tractor tires and mufflers (but not for my Oliver) and disc and harrow stuff etc. etc. clothes, raincoats, oil by the bucket... woo hoo
Great advice
Thanks guys, the push cap will work. I just wanted to verify that no one had found a source for these ( I hadn't seen any of them anywhere). I'm OK with "close" to the look, but the rusted c clip is a bit embarrassing!
Cheers
Mark
to quote Sammy Hagar...."Red, I luv Red!!!!"
Cheers
Mark
I was also looking for years for replacement caps. When I had my bench recovered, they tossed the caps (mine were like acorn nuts). Looked at the Fusik product and it is different. Fusik lists part for 64-65 bucket seat. Anyone seen a source for the orginal style. Also looking for replacement aluminum panels at bottom of seat.
Anyone got any sources. Thanks!
9drsixwheelolds
November 1st, 2010 09:15 AM
