very small question on bench seat hardware
Old Jul 9, 2009 | 06:32 PM
REDROCKER-S's Avatar
Guys, I have the bench seat arrangement in my 70 Supreme Conv., and the right side "end cap" or retainer is missing( at the pivot point from the seat back to the seat base). The previous owner installed a semi-fitting "c" pin around the seat "rod or shaft". I need to know if :
a) anyone has a spare one for $$$
b) where can I get one, short of rummaging through a yard
c) if I recreate one, anyone know what I would need as far as diameter, screw on? hammer on( I suspect)?, etc
Thanks for any light y'all can shed on this
Mark
Old Jul 9, 2009 | 07:44 PM
2blu442's Avatar
Can you post a picture of the one you do have? I'm not positive what the 1970 one looks like. John
Old Jul 10, 2009 | 03:20 AM
Yellowstatue's Avatar
Smile Be seated
I have seen those end caps at the hardware store ( around here it's Home Hardware) if you have a Tractor Supply Chain store check them out also. it is sort of like a wheel to axle retainer for utility carts, wagons, shopping carts, etc.. Sorry, I can't find a part number for you.. but there might be a bushel of them at Seven Springs next week..
Old Jul 10, 2009 | 05:22 AM
Lady72nRob71's Avatar
Rare item in perfect shape...They are not reproduced.
I researched using the bucket ones, but they are the wrong size.
Since they are a "one use" item, they are usually damaged in removal and very hard to reuse. What I ended up doing is having the uphol. shop using a plain push-on lock ring to hold the seat, then glued the chrome cap over the top as the top looked okay (lock tabs were broke).
As mentioned already, look at axle caps at the hardware stores. The ones at Lowes are ugly, but you might find some that look nice elsewhere. Try Ace or Elliott's if in your area.
Now why doesn't TSC sell tractor parts? I went in looking for some tractor tire tubes and they looked at me like I had two heads...
I cannot figure that part out for the life of me; they should change the store name.
Old Jul 11, 2009 | 04:02 AM
Smile Tubing
You are going to the wrong store!! Alliston TSC has tractor tires and mufflers (but not for my Oliver) and disc and harrow stuff etc. etc. clothes, raincoats, oil by the bucket... woo hoo
Old Jul 11, 2009 | 09:29 AM
I knew something was wrong by opening a new tractor supply store in the middle of a huge city... Maybe I can find a tube online somewhere.
Old Jul 11, 2009 | 07:09 PM
Great advice
Thanks guys, the push cap will work. I just wanted to verify that no one had found a source for these ( I hadn't seen any of them anywhere). I'm OK with "close" to the look, but the rusted c clip is a bit embarrassing!
Cheers
Mark
to quote Sammy Hagar...."Red, I luv Red!!!!"
Old Jul 11, 2009 | 09:06 PM
70Post's Avatar
Try Item A134 at Ames Pontiac Parts.
Old Jul 18, 2009 | 08:21 PM
the rod end cap from Fusick actually worked!!!! search over. Thanks guys for all the good advice..
Old Jul 18, 2009 | 09:30 PM
rcorrigan5's Avatar
Randy C.
Concur with the Fusick product. The ones I got from them for my '68 bench seat matched the one remaining cap I had before it came off.
Old Oct 30, 2009 | 06:49 PM
johnspd22's Avatar
I was also looking for years for replacement caps. When I had my bench recovered, they tossed the caps (mine were like acorn nuts). Looked at the Fusik product and it is different. Fusik lists part for 64-65 bucket seat. Anyone seen a source for the orginal style. Also looking for replacement aluminum panels at bottom of seat.
Anyone got any sources. Thanks!
droldsmorland
May 3, 2015 07:43 PM
oldspackrat
Oct 11, 2012 07:49 AM
Eddie Hansen
Paint
15
Jun 12, 2012 06:13 AM
9drsixwheelolds
Nov 1, 2010 09:15 AM
Graniteman
Feb 24, 2009 09:17 AM
