Steering Wheel Replacement Help
Old Oct 18, 2011 | 02:25 PM
Cutty72's Avatar
Bought a nice 4 Spoke wheel from another member and was planning on installing this evening. I removed the aftermarket Grant Steering wheel and billet trim ring but I can not get this damn thing off (image attached). I haven't gone all caveman on it yet...am I missing something? It seems like it should just unscrew?
Old Oct 18, 2011 | 02:54 PM
starfire's Avatar
You need a steering wheel puller to get that off. Local autoparts store should rent you one, or they are cheap enough, just buy one.
Old Oct 18, 2011 | 07:27 PM
Lady72nRob71's Avatar
If going "caveman" involves a club, do not use it. It can damage the collapsing feature of the column.
Rent or buy a puller or make your own with a plate of steel and some old long bolts that will thread into the holes and one in the center with a few nuts on it.
Old Oct 18, 2011 | 07:39 PM
Pullers are cheap.
You should have one.
Go out and spend the $15.
Live a little!
Old Oct 18, 2011 | 07:43 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Harbor Freight should have one that will do what you need.
Old Oct 18, 2011 | 08:19 PM
After you get that off....and I hope this comes across right, you do have the hub assembly and horn wire for the 4 spoke wheel?? Without the hub you can't mount the N34 wheel.
CutlassS1972
Body work
Aug 21, 2014 09:06 PM
CyberCholo
Apr 26, 2014 06:12 PM
Rdrokit
Feb 28, 2011 12:01 AM
agtw31
Suspension & Handling
15
Jun 14, 2010 06:01 AM
tarheeldoc
Sep 8, 2009 08:28 AM
