Picture of mat behind rear bench
Old Jan 14, 2014 | 09:58 PM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
Hi!
Can anybody provide me with a picture of the damping mat that's behind the rear bench in a '70 cutlass between backrest and the trunk divider sheet metal? Preferrably in place without rear seat.
Want to cut my own and want to be close to original.
Old Jan 15, 2014 | 05:29 PM
Lady72nRob71's Avatar
Are you looking for an original only or can a repop work? The latter I have...
Old Jan 15, 2014 | 09:46 PM
Nop's Avatar
Nop
I'll take anything for inspiration/orientation, thanks
Old Jan 16, 2014 | 06:06 PM
Here it is, hope it helps.
It only hangs on those two hooks in the center. I used a couple screws at the sides for my own custom installation...
I also have the factory jute mat that hangs over this on the seat side, but it is not on there yet. It is about the same size.
Old Jan 17, 2014 | 12:12 AM
Nop's Avatar
Nop
I thought there's some more magic to it than a plain square...
Thanks for the image, I'll get creative then.
Old Jan 17, 2014 | 12:54 PM
oddball's Avatar
It's been awhile, but I'm pretty sure I pulled out the stock one from a '72. The sides were scalloped a bit so the bottom was narrower than the top, maybe by 6" or so on each side, starting about halfway down.
It was just thin cardboard.
Old Jan 18, 2014 | 09:24 AM
Well I come to realize you want a picture of the mat, not the board...
Well the mat is the same rectangle as the board and hangs on the same two centerish hooks. It is about 3/8" thick.
You can see a little of my original in the following shots:
coppercutlass
Sep 5, 2012 04:52 PM
DeltaDevil88
21
Jun 14, 2012 03:36 AM
bluecab
Apr 21, 2012 05:52 AM
benji94
May 21, 2010 10:42 AM
68conv455
Oct 18, 2009 07:36 AM
