Kick panels with speaker opening?!?!?!
Old May 16, 2011 | 09:16 PM
IZAOLDS's Avatar
Dee
Looking to buy 71 cutlass kickpanels with the speaker placement not looking for those that already have them I want to add my own are there any recommendations out there? I dnt have a specific price range at the moment and Can be for components or jus coaxials thanks guys....
Old May 16, 2011 | 09:25 PM
Aceshigh's Avatar
Here ya go.
https://classicoldsmobile.com/forums...-speakers.html
I've seen the one's in Post #4 in person and they are nice.
Old May 17, 2011 | 04:08 AM
fjross's Avatar
I ended up buying the speaker panels minus the speakers from Ames Performance. The challenge will be to find a good sounding speaker with a minimum mounting depth. I originally purchased a set of Infinity 2 ohm speakers and ended up replacing them with a set of Polk Audio 4 ohm (521's). I also used the foam speaker enclosures behind the speakers to help project the sound. There is only around 2" to 2-3/8" of depth to mount the speakers so I ended up modifying the Polk provided backing rings to move the speakers out away from the metal behind the kick panels otherwise the speaker magnet touches the frame of the car. I also had to cut and re weld to offset my emergency brake pedal since it was almost hitting the speaker grill and I was afraid of damaging the grill when using the brake. The repro panels are a bit glossy compared to the rest of my black interior so I gave them a coat of Sems semi gloss as well as the silver Polk grills to make them blend in a bit better. Have not finished the stereo system yet, but I have ran all my wires to the trunk area before installing my interior. Since my car is stock, I didn't want to cut any door or kick panel metal out of the way. I'll see if I have any pic's to post when I get to work. Sonic Elextronics has some great prices,
Old May 17, 2011 | 05:08 AM
fjross's Avatar
Here are some pics of the Polk speaker installed. I have to correct myself from the previous post. The Polk speakers that I used are the 6-1/2" db621 not the 5-1/4". The first two pics before I painted the grills black.
Old May 17, 2011 | 12:00 PM
IZAOLDS's Avatar
Dee
Sweet man nice ride too thanks
davoaz
May 1, 2015 11:51 PM
speck1148
Dec 21, 2014 10:26 AM
ThePackRat
Jan 2, 2014 08:52 PM
Grant1424
Feb 18, 2013 04:43 AM
Bobac455
Sep 7, 2010 11:47 AM
