Is this correct shifter for 69 automatic
Old May 17, 2011 | 08:11 PM
69OLDSCUTCONV's Avatar
Purchased this shifter with console from a friends friend that i plan to use on my cutlass 350 turbo then 400 turbo later this summer or winter whichever come first ? haha. Its was suppose to come out of 69 cutlass, console looks correct for 69 but shifter im questioning. My issue is looking at it and operating it, it appears to work like its for a 2 speed tranny, low or 1st gear is all the way down and it has detent to get into low, but when you shift forward to 2nd then what i think is further up its neutral the you have to detent to get to reverse and then park is the simple one.?? maybe it will make more sense once I it get it mounted just didnt want to go thru that if I didnt understand it first. I do have a spare tranny maybe that will help if someone doesnt have any ideas on here.
Old May 18, 2011 | 02:26 AM
jensenracing77's Avatar
without having mine in front of me i think you are right. i think there should be one more step in the back. the wide spot in the middle is drive on the back side and neutral on the front side.
Old May 18, 2011 | 02:57 AM
Yellowstatue's Avatar
That piece with the detents unbolts and you replace it with one for a three speed...otherwise it is the same...
Old May 18, 2011 | 05:06 AM
507OLDS's Avatar
It could have come from a 67 or 68,with a 2-speed.All you would need to do is change the detent piece,with one from a 69-72.The chrome handle & floor bracket are the same.
Old May 18, 2011 | 07:25 AM
69442C's Avatar
The detent on your shifter is for a 2 speed automatic. Attached is a photo of a shifter with a 3 speed detent plate. As mentioned, find the 3 speed plate and bolt it in place of the existing one.
Old May 18, 2011 | 07:34 AM
starfire's Avatar
Dang that's a nice looking shifter!!!!!
Old May 18, 2011 | 07:47 AM
69442C's Avatar
Thanks Alan. It didn't look that way when it was removed from the car but with a little work, a new neutral safety switch and new chrome on the handle assembly, it turned out pretty nice. The base was bead blasted and painted with Eastwood Spray Gray, the detent was sprayed flat black and new hardware was installed. Too bad it's not visible when the console is in place. Oh well, I'll know it was done.
Brian
Old May 18, 2011 | 03:34 PM
Thanks guys
I got the correct detent form the guy tonight he had two more shifters just an oversight on his part. Thanks
harleyrules
Nov 9, 2025 06:52 PM
Christophe2m6
Oct 27, 2014 01:01 PM
64starfire
Apr 17, 2009 05:29 AM
Oldsproject
Jun 11, 2008 07:56 AM
denis
Feb 22, 2007 11:51 PM
