Kick Panels Cutlass 1966
Hello
Looking after kick panels for my 66 Cutlass, the ones I removed had the vent flaps but when I look at OPGI.com page they are without the flaps. But if I look for panels for a 67 Cutlass at the same dealer I could buy them with the flaps? Should the 66 have these vent flaps or not? I guess the 67 will fit since the body is the same. Just wonder since they not list the panels with flaps for the 66. Someone out there who knows?
Hello
Do not use use the catalog of an aftermarket vendor as a source of information like this - they are frequently incorrect.
1964-67 A-body kick panels are the same. There are two styles from the factory. Those with vents were used in non-A/C cars and those without vents were used in A/C cars. You can also get aftermarket versions that have speakers.
The 66's with A/C I have seen used the vent style panel with a block off plate over the cowl hole. I'm not sure about 64/65 but I'm sure about 66.
