Glove compartment lock
Old Oct 11, 2021 | 05:27 AM
MichelS's Avatar
Hi.
my first question here is.
My glove compartment is locked but the lock will not open.
That is what I call tough lock....
Anyone has any ideas to solve this?
Tnx
Old Oct 11, 2021 | 06:14 AM
Most likely you'll need to purchase a new car.
On a more serious note, first: state the make, model & year of your vehicle since both locks and glove compartments vary by make, model & year. Someone my have a suggestion/solution.
Old Oct 11, 2021 | 09:42 PM
7314haywood's Avatar
Lock
Have a locksmith pick it open. I can't think of a year that a glove box can't be picked Take apart and see why your key does not work.
Old Oct 11, 2021 | 11:27 PM
MichelS's Avatar
Tnx
Tnx. But the key turns and the last time I heard a spring or something else sort of got loose. So maybe a new car will be the best option 😂😂.
I will have a locksmith to have a look at it
Old Oct 12, 2021 | 04:14 AM
JohnnyBs68S's Avatar
It appears that your glove box lock is working exactly as designed.
I have to assume that you don't have a key for the glove box lock. If that is the case, the only solution I can see (without destroying the glove box door) is as haywood suggested: Have a locksmith pick it open, and then take it apart to have a new key made for it.
Old Oct 12, 2021 | 06:15 AM
MichelS's Avatar
Key
Well.
I have the key. It turns the lock. But I cannot see the latch responding. I thought maybe the 3 bolts in the lower part to unbolt. Or is this not possible
Old Oct 12, 2021 | 06:26 AM
3 bolt lock doesnt come to mind. 2 bolt on 60 and 70 year vehicles. If it is in the unlocked position the thumb turn/ cylinder can be removed. Possible back of cylinder has the tailpiece broke. Then a screwdriver in housing and rotate. Need year and model and I should have explored view of assembly
Old Oct 12, 2021 | 06:34 AM
Phoenix8990's Avatar
It also sounds like it may be an adjustment of the latch/catch, either way, maybe slide a plastic tool in and try to pry slightly. It may pop open.
bobfo1
Jul 10, 2021 10:40 AM
jdana24
Oct 18, 2020 06:34 PM
matt69olds
Oct 13, 2020 08:22 AM
GCH
Jun 7, 2019 05:01 AM
chip-powell
Feb 4, 2016 01:39 PM
