get rid of mildew? best way to clean old interior plz help
Old December 25th, 2013 | 09:14 PM
odddoylerules's Avatar
is the search function on this site dysfunctional? Don't mean to sound needy but I cant find d!ck on this subject by searching, and my interior is in need of cleaning real real bad. Any tips? Links to good info? am i just retarded and have there already been a million posts like this?
lay it on me!!
point me the right direction and i'll shut up lol -Merry christmas!!
Old December 25th, 2013 | 09:30 PM
billmerbach's Avatar
major noob
I used vinegar and lemon solution
Old December 25th, 2013 | 10:40 PM
RROLDSX's Avatar
A little bit of bleach and water on vinyl is OK, then wipe with water. Final clean with lemon pledge. Mold in the carpet use a little bleach ( 1 cup for 5 gallon pail of water) or Simple Green (amazing stuff). Then soak the carpert thoroughly with water and shop vac it back out until dry. Vinegar and lemon works good too! Happy scrubbling and Merry Christmas.
P.S. For those hard to get out stains in vinyl you can use a little laquer thinner on a rag and rinse afterward.
Old December 25th, 2013 | 11:52 PM
5998DownUnder's Avatar
For mildew I used saddle soap. I got the stuff from horse accessory stores where you buy saddles/bridles etc.
Saddle Soap with clycerine is the stronger.
Old December 26th, 2013 | 11:50 AM
good places to start, thanks guys. everything I googled said not to use on porous surfaces, and my passenger seat sure isn't made of bathroom tile...
Old December 26th, 2013 | 11:52 AM
coppercutlass's Avatar
Chevy budget Olds powered
If it's the interors try baking soda. LOTS of it lol. On the carper on the seats. Then leave a few boxes open to suck in bad odors. The baking soday vaccums up then fabreeze it. You can also buy one of those moisture sucker buckets for basements and try that. But I have done the baking soday and fabreeze trick before and it worked. This is only for smell.
Old December 26th, 2013 | 12:05 PM
455Olds's Avatar
I've had good luck with simple green too. Dilute it like the directions say. It's STRONG undiluted.
Old December 27th, 2013 | 11:31 AM
navvet's Avatar
Got to find the cause of the mildew also. Make sure under carpet is dry. When I first got my car I placed a dehumidifier in the car and closed windows. I put a board on the front seat and placed the machine on it. I ran it for @ 15 hours. When I pulled the bucket out it had over a gallon of water in it. Obviously I did it when it was cool and dry outside ( I think it was early April) I did this two more times until no more water was collected. I used a small amount of bleech in my bucket with water. When that was complete I cleaned it again with a lemon cleaner..it helps remove the mildew and bleech odor. I then finish with a auto apholstery cleaner purchased at a parts store. No more odor and good color returned to the interior.
DownBoy
August 20th, 2014 09:53 PM
cadillac kevin
May 5th, 2014 09:01 PM
ATrain1
Non-Olds Engines
June 29th, 2012 01:58 PM
MDchanic
May 1st, 2012 01:58 PM
bobb
October 4th, 2010 07:02 AM
