Gear Indicator
Old Jul 31, 2019 | 06:15 AM
Phoenix8990's Avatar
Gear Indicator
I'm not sure where to post this question, but here goes. I have a 69 Cutlass S conv. automatic on the column. I am pretty much doing a fairly complete budget restoration. I've had the car stripped and painted and am now doing the interior. My question is how to repair the gear indicator. Currently I have to feel my way into whatever gear I want. Is it mechanical or electrical?
thanks,
Steve Worthing
Old Jul 31, 2019 | 06:26 AM
Steve, you can get aftermarket shift indicators:
https://www.summitracing.com/search/...8%2B4294882857
The part that is broken or missing is just an indicator. If you disassemble the shift quadrant in your steering column you may be able to repair the indicator. I looked at Fusick, Kanter and Year One and wasn't able to find a replacement indicator. Hopefully someone else knows a source for this part besides a salvage car.
Old Jul 31, 2019 | 06:38 AM
Is it mechanical or electrical? I have the steering column lowered at the moment and don't see anything on it and have had the speedo out and see nothing. How does it work, i am baffled.
thanks,
Steve
Old Jul 31, 2019 | 08:34 AM
It's mechanical. There should be an orange indicator that moves when you change gears on the column. Here's a column shift quadrant from a similar year Chevelle. I doubt it would work in your Oldsmobile but at least it gives you an idea:
https://www.opgi.com/chevelle/CH2085...yABEgKG6PD_BwE
Old Jul 31, 2019 | 08:47 AM
Isn't there a thin cable that connects from the shifter arm to the indicator mechanism?
Old Jul 31, 2019 | 12:12 PM
Gpc1's Avatar
The thin cable is probably broken . I think it’s spring loaded so might have retracted
have fun
Old Aug 6, 2019 | 11:30 AM
Toms cutlass's Avatar
thanks,
Steve
There's a wire link that connects the shift column to the speedo gear shift indicator. This guy sells the wire linkage > https://www.ebay.com/itm/1970-1971-1...MAAOSwW0Vb3Mdj Also, on some A/T speedometers, the off-white plastic gear selector is broken off where that linkage connects. If that's the case, you need to contact one on the parts guys here on CO who can source you that part.
Old Aug 6, 2019 | 12:47 PM
rcorrigan5's Avatar
Randy C.
he off-white plastic piece out from back of the speedo pod is what moves the PRNDSL needle.
This pic shows the wire piece that connects to the off-white plastic piece. It almost looks like the wire piece could be made from a paper clip.
And this is where the wire piece connects onto the steering column.
Old Aug 6, 2019 | 01:21 PM
Related thread > https://classicoldsmobile.com/forums...hook-up-59463/
Old Aug 6, 2019 | 05:46 PM
Thanks, that shows it all pretty clearly.
Steve
rmoths
Dec 6, 2021 09:29 AM
olds 307 and 403
Jun 10, 2017 04:25 PM
ent72olds
Apr 12, 2013 05:13 PM
tarheeldoc
Jun 5, 2009 11:38 AM
FATRATMATT
Oct 16, 2008 04:21 AM
