door panel to rear panel alignment
Old October 2nd, 2018, 05:48 AM
Drsantos's Avatar
What would cause these 2 panels to be out of alignment?
Drsantos is offline
Old October 2nd, 2018, 07:45 AM
edzolz's Avatar
How about a picture inside of the door with the door open. From this angle, it appears the door panel is the wrong one for this body and the matching inside quarter was somehow made to fit. Possibly a door panel from a four door attached to the two door body.
edzolz is offline
Old October 2nd, 2018, 08:17 AM
Drsantos's Avatar
Will take a better pic later
Drsantos is offline
Old October 2nd, 2018, 08:06 PM
70Post's Avatar
What Ed said....the rear panel looks to be way too long. What the heck is going on there?
70Post is offline
Old October 3rd, 2018, 09:58 AM
Drsantos's Avatar
more pics
rear panel
Drsantos is offline
Old October 3rd, 2018, 06:03 PM
Phantom Phixer
Charlie Jones's Avatar
The striker bolt needs to be loosened up and moved inboard slightly .
When I posted this I didn't realize you were talking about the interior .
The door itself is slightly out of line with the quarter panel . Moving the striker bolt inward will correct this mis-alignment , and it will help with the interior alignment .
The rear seat panels have a metal "rail " in this area underneath the upholstery . Perhaps this is bent .
Charlie Jones is offline
Old October 3rd, 2018, 07:19 PM
70Post's Avatar
Are you sure it isn't just the door panel edge catching/hitting the leading edge of the rear panel and pushing it inward?
70Post is offline
Old October 3rd, 2018, 07:20 PM
ragz442's Avatar
I don't own '69 vert, but restored a '72 Lemans convertible years ago that I had for about 10 years. Looks like some type of shoddy body/interior work or incorrect trim panels??? What's the other side look like?
ragz442 is offline
Old October 3rd, 2018, 08:10 PM
steverw's Avatar
Are those the original panels to this car? Or from another 69 convertible?
looks like the door panel is too short and the rear panel is too long. Cant say ive ever seen a vert with the door open but....
steverw is offline
Old October 3rd, 2018, 08:59 PM
70Post's Avatar
I thought the same thing but after looking at the latest pics you can see the metal inside the QP jamb is well forward of the door opening line....so it looks like the panel needs to be that long to cover it all. Same thing on the door panel itself.
I think it's a "panel hitting/interference" problem but will wait to hear again from the OP.
70Post is offline
Old October 4th, 2018, 06:10 AM
Drsantos's Avatar
those are the original panels, since I have own the car, the passenger side is better than the drivers side.
Drsantos is offline
Old October 4th, 2018, 09:53 AM
ragz442's Avatar
I was curious and googled 69 cutlass convertible interior pics, did not realize that was the way they were designed. Seems my Lemans door panels went to the edge of the door like the hardtops but I could be mistaken. After looking again I would say the quarter trim panel is not installed correctly. I would remove remove rear seat bottom and quarter trim. The inner sweep may be bent and not catching in the right spot. Seems like rear seat entry is hazardous with the way they designed those trim panels....lol
ragz442 is offline
Old October 4th, 2018, 10:26 AM
Randy C.
rcorrigan5's Avatar
This is what it looks like on my '69 4-4-2 convertible, if it helps.
Randy C.
rcorrigan5 is offline
RandyS
March 29th, 2018 09:00 AM
m371961
March 30th, 2016 11:13 AM
W-27
December 26th, 2013 06:03 AM
oldgold
July 2nd, 2012 08:10 AM
Dave in MN
Aurora
June 17th, 2010 03:21 PM
Quick Reply: door panel to rear panel alignment
