Amateur Door Panel Rebuild
Old Mar 19, 2016 | 10:10 AM
m371961's Avatar
Before and after.
Old Mar 19, 2016 | 10:22 AM
Very nice
Old Mar 19, 2016 | 10:27 AM
RetroRanger's Avatar
72 Olds CS
Well done a big improvement you see every time your in the car!
Old Mar 19, 2016 | 11:13 AM
m371961's Avatar
Thanks. Up close I see every mistake I made.
Old Mar 20, 2016 | 12:09 PM
Nothing amateur about that! great job.
Old Mar 21, 2016 | 12:56 PM
D. Yaros's Avatar
While you may be able to see every mistake, others do not. The end product of your efforts is impressive!
Old Mar 21, 2016 | 01:18 PM
m371961's Avatar
Thanks, I enjoyed doing it, had a local upholsterer do the armrest cover.
Old Mar 21, 2016 | 01:47 PM
RAMBOW's Avatar
Ben
Looks good!
Question- do they have a formed steel top rail under the vinyl, or is it just a vinyl flap that wraps over and clips into the window channel?
Old Mar 21, 2016 | 03:08 PM
m371961's Avatar
Steel top rail under vinyl, was pressed into panel board. I removed board, ground down the rail and glued and riveted rail to new board with countersunk rivets. There were some small dents in the rail I didn't see until vinyl was down. Should have been filled.
Old Mar 21, 2016 | 04:26 PM
76olds's Avatar
Hookers under Hood
I agree with everyone, looks very nice. Something to be proud of every time you get into your car. Upholstery work takes alot of patience , you nailed it with a Job well done.
Eric
Old Mar 24, 2016 | 04:28 AM
m371961's Avatar
moving on
Rambow- How did the factory staple to the metal?
To the rear panels. I would need more vinyl and work done at the upholsterer to continue, so i am thinking this.
1st pic- There is a tear in the top center of the panel
2nd pic- Thinking SEM and some customizing with some stuff I have laying around. What do you think? The cardboard is roughly the seat line.
Old Mar 30, 2016 | 11:13 AM
m371961's Avatar
Got Wood
Instead of using carpet to trim it out.
m371961
Dec 14, 2015 05:49 AM
onofre442
Dec 1, 2013 10:36 AM
rsylvstr
Jul 5, 2010 02:35 PM
my69olz
Care and Appearance
Jul 8, 2009 10:31 AM
