Delta 88 Interior Instrument/Dash Panels
Old Jan 15, 2021 | 02:34 PM
EsoWuhn's Avatar
I have the idea to take the plastic one piece wood-grain trim where my heater controls are, as well as the one where the headlight switch sits; and revamp/fabricate new ones for my 1980 Delta 88. The problem is I'm not entirely sure of the RIGHT material to use. I've popped the panels off millions of time and I'm almost certain it's a hardened plastic; but if I'm going to be fabricating them the best material to use. Speaking with a couple of my guys, I've heard to use wood and then treat it for moisture resistance and everything; and I'm sure that's a great idea....I'm just not entirely sure. I know wood is prone to flexing/bending/warping given the temperature and outside conditions (she IS my daily driver.), and was wondering if anyone had any experience with this or any ideas as to a material to use. Any help is always appreciated, thank you fellas.
Old Jan 16, 2021 | 04:14 AM
Bfg's Avatar
Bfg
Sounds like a bad idea
Old Jan 16, 2021 | 06:49 AM
EsoWuhn's Avatar
What are you saying is a bad idea, and why?
Old Jan 16, 2021 | 09:53 AM
Bfg's Avatar
Bfg
Sounds like a lot of extra work to try to fabricate a wood panel to fit in the dash. Although If you are a master woodcarver this is probably right up your alley. Just saying!
Old Jan 16, 2021 | 11:03 AM
EsoWuhn's Avatar
I mean that was the point of the thread. I asked if anyone had any advice, or suggestions as to any other materials I may use besides wood.
As far as the work; I’m almost inclined to say its LESS work than rebuilding a motor or swapping a transmission. The work isn't the problem or in question; its a matter of materials.
So did you have any suggestions or ideas? Or were you simply trying to tell me its unnecessary?
Old Jan 16, 2021 | 11:41 AM
Bfg's Avatar
Bfg
I have a complete panel that snaps into the dash that is in excellent condition if you are interested. Or is this something that you want to eliminate and custom make? As far as making it moisture resistant, I can’t see how this is subject to moisture unless you have a leak in your roof
Old Jan 16, 2021 | 12:09 PM
EsoWuhn's Avatar
My panel is just fine, I’m doing this more for customization. My Olds is completely different than any Olds I’ve seen on the site as far as how I’m building it, so there will be a fair amount of customization work.
I was worried about moisture moreso with using wood. I wasnt sure if there WOULD or wouldn’t be; I’m just the type of dude to have my ducks in a row before i start.
Old Jan 16, 2021 | 12:20 PM
Bfg's Avatar
Bfg
Ok, I see, blast away!
KetsMcLets
Feb 25, 2015 12:25 PM
eudaman
May 19, 2013 05:30 PM
mista.big
Jan 28, 2013 10:35 AM
hkr
Mar 28, 2011 06:34 AM
RPMRestoAndCustom
Feb 28, 2011 09:49 AM
