Dash Swap — Any “Must Do” Items??
Old Aug 2, 2024 | 09:09 AM
mapearso's Avatar
Swapping out the cracked dash and tired cockpit on my 1978 Delta 88.
Steering column and dash are already out.
I have very nice uncracked dash pad and cockpit parts ready to go in.
Before I install the parts are there any “Must Do” or “Probably Should Do” items?
For example, when I swapped out the dash on my 1989 Mercedes SEC I replaced all the A/C pods.
I’m attending to a couple of surface rust spots but not planning on anything else … unless there are Must Do / Should Do items that I’m not aware of …
I look forward to your replies. Thanks
Old Aug 2, 2024 | 11:58 AM
Sugar Bear's Avatar
Adding sound deadening material e.g. Dynamat???
Old Aug 2, 2024 | 12:38 PM
Ensure the HVAC is performing optimally.
Old Aug 2, 2024 | 01:07 PM
lshlsh2's Avatar
71 cutlass convertible
Clean grounds. Maybe replace all the 40 plus year old light bulbs. You know the ones that will blow a week after you put everything back together.
Old Aug 2, 2024 | 01:20 PM
Tuffnut's Avatar
Check the steering column turn cam or replace it. Grease the column bearings. Maybe paint the column if it’s not in good shape.
Bulbs for sure. Check/ replace front speakers if you use them if they are in the dash,
a few thoughts while you are in the neighborhood.
Old Aug 2, 2024 | 01:34 PM
Supernice88's Avatar
Art S
Don't over tighten the fasteners that hold the plastic tabs.
Chuxter
Apr 19, 2023 05:43 AM
brotherGood
Dec 1, 2022 07:00 AM
1970greensupreme
Jan 30, 2017 06:41 AM
feehanr
Oct 27, 2009 08:09 AM
mike14_07
Jul 14, 2009 07:52 AM
