Dash restoration
Old Jan 29, 2017 | 11:58 AM
1970greensupreme's Avatar
Dash restoration
I'm looking to get my dash pad repaired and dash restored. It would be mint if not for a crack dead center of the windshield on the pad only. Has any member had any luck with just dash's and I've also looked a bit at classic car plastics for the job. Worst part was getting the thing out without damaging anything else. Those retaining nuts are impossible to see/get to
Old Jan 29, 2017 | 05:52 PM
oddball's Avatar
The general feedback is Just Dashes does excellent work. And they charge appropriately. The dash will look more plus/swollen than it does now, but it'll be soft and will stand up to use.
Keep an eye on the for sale and post a wanted ad. Good dash pads show up fairly regularly. It's particularly easy if you're willing to paint it to get your color.
Just make sure the seller bolts a plastic lower dash to the dash pad before shipping it. Shipping a bare dash pad, regardless of how well packaged, is just asking for a big crack in the middle.
Getting the dash assembly out is much easier after the 6th time.
Remove the seats, get some flashlights and a good deep socket (11/32nd, right?) The one tucked next to the steering column is the one I hate.
Old Jan 29, 2017 | 06:22 PM
Gary M's Avatar
Hope these are all of them. Just be gentle.
Pass side one near bottom and one above both sides of the glove box may be one between vent and pass side of dash too.
One on bottom each side of radio
Near steering column on pass side of it
Driver side of radio
Near light switch
Driver side between vent and end of dash. Mine is broke off
Old Jan 29, 2017 | 06:35 PM
Gary M's Avatar
Mine is a 72. Clarification may be needed
oddball did I miss any?
Old Jan 29, 2017 | 07:19 PM
70Post's Avatar
The last pic Gary shows (fastener is broken off) is typically NOT a attachment location with a nut. Due to the horrific lack of access (from under/behind the dash) the factory DID use a threaded stud in the dashpad (like the others) BUT I'm fairly sure there is an insert in the dash metal hole/receptacle.
The "insert" is a stamped metal thing that basically has barbs or fangs that grab the threads on the stud once it's pushed in and this keeps the dash from coming loose on that end.
It can be a struggle to get the pad loose from that fastener but folks are doing it all the time so be patient on that one.
At least this may save the OP some trouble if he thinks there's supposed to be a nut holding the stud on the D side end of the pad.
As far as replacing it....I'd find the best original pad you can and freshen it up with some vinyl/plastic paint/dye. You'll be many $ ahead VS. those places that re-cover the pads and you won't have problems I've read with things like the channel for the "chrome" dashbead molding being too thin to accept a new molding or the loss of detail lines that are in the original molded vinyl pad surfaces.
You'll also save HUNDREDS of $ going with a nice original pad.....$ you can spend on the rest of the interior if you are redoing other parts inside. Shipping cost alone (both ways) is not going to be pretty.
Edit: Who is "classic car plastics"??
Old Jan 29, 2017 | 07:44 PM
Getting the one for the dash pad, far left just inside of the dash vent was a bear. I ended up taking out the vent and the duct and was able to get in there. It was stuck and didn't want to crack the dash even though it wasn't a nut holding it. Thanks for the tip, I"ll keep my eyes open for a dash. Since mine is black it should be easy to match
Old Jan 30, 2017 | 06:41 AM
oddball's Avatar
Gary, the attachment is identical 70-72, regardless of options. Well, except for where it's been broken by a previous owner.
IIRC, there are:
2 nuts on the far right (passenger) side
2 nuts above the glove box
4 nuts along the bottom of the lower dash
2 bolts between the gauges going into the dash
1 pinch retainer by the driver's vent - no nut, but as noted may have to push from inside if it's gotten really stuck
Your dash is black? Man, jackpot. You can get any dashpad and slather on some black vinyl paint. I know Landau is the best match for plastics, probably the same for vinyl. That paint is pretty resilient with correct prep.
A plastic welding kit may also come in handy to repair tabs, especially the glove box door bumper tabs.
also, keep a plastic lower dash bolted into any dash pad that you are storing. I made the mistake of storing my really good pad without a dash, and it lost the slight curve in the top. Some time with a heater and bolting one back in got it back though.
Del70
Jul 21, 2020 11:42 AM
Raivjudge
Jan 30, 2012 09:44 AM
skryla
Jul 22, 2011 12:51 PM
67442inmontana
Jan 9, 2009 09:43 AM
gow589
Apr 18, 2007 07:36 AM
