Convertible top question
Old February 17th, 2012, 08:08 AM
joeype's Avatar
I am getting ready to order a new top for my 68 from yearone. I plan on buying the top with glass. My question is...does anyone know if the glass comes separate or already attached to the top?? Thank you!!
joeype is offline
Old February 17th, 2012, 08:22 AM
The glass is part of the rear "curtain," which is separate from the main part of the roof, and must be installed using its own separate part of the installation procedure.
I can't say whether it is shipped attached to the top or not, but it has to be set up as though it is a separate part, in order to get the best result.
MDchanic is offline
Old February 17th, 2012, 08:33 AM
joeype's Avatar
Thank you Eric...
joeype is offline
Old February 17th, 2012, 08:41 AM
allyolds68's Avatar
The rear glass is a completely separate piece that is not attached to the top. I bought mine from Fusick & it was cheaper than YO even with their everyday 30% discount
allyolds68 is offline
Old February 17th, 2012, 09:02 AM
joeype's Avatar
Thank you, Mike
joeype is offline
Old February 17th, 2012, 09:19 AM
delete
droptopron's Avatar
There are also a number on vendors that specialize in convertible tops you can find in Hemmings. I'd check them also. They may be able to give you more insight if you need anything add'l like pads or cables.
droptopron is offline
Old February 17th, 2012, 09:33 AM
... And though you may not need cables (if yours are fine, they'e fine), you should change the pads, unless the car has spent its life in a dry garage since the last top was put on (and even then you may need them). Just a heads-up: Once the pads are off, you'll lose a few measurements and have to re-set them according to the manual.
MDchanic is offline
Old February 17th, 2012, 09:36 AM
allyolds68's Avatar
When I was doing mine a did a Excel spread sheet comparing about 5 vendors. The prices of each individual part (top, rear window, pads, cables, the fabric piece that runs over the rear bow, etc) were significantly different from vendor to vendor. I'm sure the quality varies also but I can usually count on Fusick to carry the best products (yeah, I'm aware of the fact that their headlight surrounds have problems and they carry PUI instead of Legendary). They have a great advantage for me because I'm usually are in their neighborhood every couple of months so I don't have to pay shipping.
Make sure you find a good source for tack strips. If yours has never been replaced, it will likely be junk. I got mine at an upholstery shop.
BTW, I never did the top, I only replaced the rear window. I just didn't have the $$$ to do everything last year.
Old February 17th, 2012, 09:40 AM
Lady72nRob71's Avatar
And as always, make sure you find out what brand of top you will be buying before you buy. If you will be having a trim shop install it, tell them what brand it is. Some they love, some they will not even touch due to quality issues.
If Year One is still selling Kee tops, then you're good - most shops like them as they are good quality.
Lady72nRob71 is offline
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
ros6872
October 31st, 2014 05:04 PM
cfair
June 30th, 2012 10:07 AM
Bobac455
August 27th, 2011 03:20 PM
Olds luvr
December 2nd, 2010 08:26 AM
Quick Reply: Convertible top question
