Convertible top question
Old Feb 17, 2012 | 08:08 AM
joeype's Avatar
I am getting ready to order a new top for my 68 from yearone. I plan on buying the top with glass. My question is...does anyone know if the glass comes separate or already attached to the top?? Thank you!!
Old Feb 17, 2012 | 08:22 AM
The glass is part of the rear "curtain," which is separate from the main part of the roof, and must be installed using its own separate part of the installation procedure.
I can't say whether it is shipped attached to the top or not, but it has to be set up as though it is a separate part, in order to get the best result.
Old Feb 17, 2012 | 08:33 AM
joeype's Avatar
Thank you Eric...
Old Feb 17, 2012 | 08:41 AM
allyolds68's Avatar
The rear glass is a completely separate piece that is not attached to the top. I bought mine from Fusick & it was cheaper than YO even with their everyday 30% discount
Old Feb 17, 2012 | 09:02 AM
joeype's Avatar
Thank you, Mike
Old Feb 17, 2012 | 09:19 AM
droptopron's Avatar
delete
There are also a number on vendors that specialize in convertible tops you can find in Hemmings. I'd check them also. They may be able to give you more insight if you need anything add'l like pads or cables.
Old Feb 17, 2012 | 09:33 AM
... And though you may not need cables (if yours are fine, they'e fine), you should change the pads, unless the car has spent its life in a dry garage since the last top was put on (and even then you may need them). Just a heads-up: Once the pads are off, you'll lose a few measurements and have to re-set them according to the manual.
Old Feb 17, 2012 | 09:36 AM
allyolds68's Avatar
When I was doing mine a did a Excel spread sheet comparing about 5 vendors. The prices of each individual part (top, rear window, pads, cables, the fabric piece that runs over the rear bow, etc) were significantly different from vendor to vendor. I'm sure the quality varies also but I can usually count on Fusick to carry the best products (yeah, I'm aware of the fact that their headlight surrounds have problems and they carry PUI instead of Legendary). They have a great advantage for me because I'm usually are in their neighborhood every couple of months so I don't have to pay shipping.
Make sure you find a good source for tack strips. If yours has never been replaced, it will likely be junk. I got mine at an upholstery shop.
BTW, I never did the top, I only replaced the rear window. I just didn't have the $$$ to do everything last year.
Old Feb 17, 2012 | 09:40 AM
Lady72nRob71's Avatar
And as always, make sure you find out what brand of top you will be buying before you buy. If you will be having a trim shop install it, tell them what brand it is. Some they love, some they will not even touch due to quality issues.
If Year One is still selling Kee tops, then you're good - most shops like them as they are good quality.
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
ros6872
Oct 31, 2014 05:04 PM
cfair
Jun 30, 2012 10:07 AM
Bobac455
Aug 27, 2011 03:20 PM
Olds luvr
Dec 2, 2010 08:26 AM
