Carpet Install for 4 speed, non-console
Old Mar 20, 2019 | 05:57 AM
Kevin W's Avatar
On a 4 speed, non-console car, does anyone know if the carpet is sandwiched between the rubber boot and retaining ring or do you install the boot, retaining ring and then carpet? There was any carpet in the car when I bought it and all my other cars have been console cars.
Old Mar 20, 2019 | 10:59 AM
costpenn's Avatar
What year? 70-72 cars do not use a retaining ring - the boot is attached directly to the hump flange around the shifter opening with 8 short sheet metal bolts. (the bolts are hidden by the lower "bellows" part of the boot) The carpet goes underneath the boot.
Old Mar 20, 2019 | 11:49 AM
Kevin W's Avatar
Originally Posted by costpenn
what year? 70-72 cars do not use a retaining ring - the boot is attached directly to the hump flange around the shifter opening with 8 short sheet metal bolts. (the bolts are hidden by the lower "bellows" part of the boot) the carpet goes underneath the boot.
1968.
Old Mar 20, 2019 | 12:37 PM
Oldsmaniac's Avatar
I do not put the carpet under the retaining ring on the boot. The shifter boot has the extra rubber to lay on the floor over the carpet. So you cut the carpet so it just touches the retaining ring. This way the boot sits down low and its plenty hard enough to put the screws in alone I cant imagine trying to send them thru a carpet as well.
Old Mar 20, 2019 | 02:02 PM
Kevin W's Avatar
Thank you, so much, I wasn't sure how they did from the factory. I tried to install with the carpet between the boot and retaining ring and it was a nightmare, carpet onto of the trim ring will 10 times easier.
Her69olds
Oct 12, 2015 08:05 PM
Dale Von Krosigk
Aug 1, 2013 10:38 PM
vsupreme
May 17, 2013 07:21 PM
69OLDSCUTCONV
Jun 8, 2011 09:43 AM
ctreutel
Jul 4, 2009 03:39 PM
