Brake Release Handle Installation?
Am trying to install the factory replacement brake release GM handle (P/N#3893179) on the parking brake mechanism. The old one was broken and I wound up having to twist the remains off with a pair of vise grips. The new one doesnt seem to want to be pressed on very easily, and I'm afraid of breaking it by using too much force. Is there a tip on how to install it?
Also, the replacement part looks significantly (at least to me) different than the OEM - handle is "thicker" and the font used is a little fatter.
I've seen these on ebay often, but never purchased one. Is that where you got yours? My only thought is to drill it out a little larger and use expoxy to attach it. I know using it will be putting pressure to pull it off. I'm not sure how the factory ones were installed. Anyway, TTT to see if anyone else has some thoughts. John
Mine broke too. I pulled the whole e brake ratchet thingamajig out of a junker just for the unbroken handle. Maybe you can run a die on the metal rod to make some threads and then tap the handle and screw it on? I never had the actual handle off...
widowmaker1201
December 2nd, 2012 01:27 PM
