Black interior
Old May 4, 2012 | 01:05 PM
XTREMEGSXR's Avatar
Black interior
Just bought a 70 cutlass F85. I want to change the interior to black. Any help on parts would be great. I have found a lot of parts, but no black dash. I need a complete black dash. Thanks!!!!!!!!!!!
Old May 4, 2012 | 01:46 PM
Don't get in a hurry. You already have a black dash but don't realize it. The dashpad on your car can be removed, degreased and dyed black. Autozone or O'Reillys can provide you with the degreasing agent (takes off old armor all and 'preservatives' put on by other owners) and spray dye. Takes some work, but then again you were prepared to take it out anyway to 'replace' it right?
BTW, that process will also work on seats, door panels etc. Doesn't matter whether its plastic or something else. The spray dye can also be used to brighten your carpet if it's in decent shape too.
Old May 14, 2012 | 05:59 PM
Chumley's Avatar
That's the beauty of black interior. You can paint the parts you need to without having to deal with an accurate match in color. I changed the interior of my '72 from white to black. Everything was new from Legendary except for the windlace, front pillar covers and the headliner and window trim lace. All of which I painted black with SEM Flexible coating. They turned out great. Fortunately my dash was already black. Chumley
Old May 14, 2012 | 06:07 PM
tecar442's Avatar
Just be sure you follow the directions and take no shortcuts. It is not difficult. I did my interior in red and it turned out beautifully. Yours will, too.
Old May 14, 2012 | 06:26 PM
Pacecar's Avatar
I also used the SEM Landau Black on my dash to freshen it up. for a change of color that is what I would use
Old May 16, 2012 | 01:31 PM
AGK's Avatar
AGK
How well does the spray dye work if you are going from white to black? Assuming you have to be somewhat careful so it doesn't turn out splotchy?
Old May 16, 2012 | 01:51 PM
lunaboy's Avatar
The Rocket Astronomer
I have the black dash , no pad and i have the windlace, front pillar covers and the headliner and window trim lace. All of which are oem black. pm if interested
Old May 16, 2012 | 04:20 PM
If you prep right (degrease, clean, rinse) the spray black dye does a great job of covering. As with all sprays it's best to do 2 or 3 light coats instead of a heavy drippy one. The dye soaks into the door panel or plastic very well. I've used it with great success even on my original carpet.
Old May 16, 2012 | 05:28 PM
RetroRanger's Avatar
72 Olds CS
SEM brand is all I have experience w and it works good.
on some old mustang seats i went from green to blue and they came out perfect.
I recently used it to go from green to black on seat covers and black to black on hard seat parts all look nice
like alan said several light coats works best for coverage and evenness
before
after
4speed455
May 29, 2017 06:38 AM
Stefano
Nov 26, 2014 11:23 AM
Magna86
May 12, 2014 05:14 AM
capstoneclub
Mar 27, 2014 10:15 AM
Vader
Jan 7, 2012 05:12 AM
