72 4sp center console restoration question
Old Sep 14, 2019 | 05:25 AM
72442455's Avatar
Joe Ralph
Hi all - been reading up - and got a good idea on paint and trim and what not for my center console - mines in pretty good shape except the underside plastic cross bar thingys that the bolts go through to attach to the welded holders in the floor ... they are cracked - they are still there enough to use big washers to grab onto the existing material but the whole console is a bit shakey when installed.
Has anyone here repaired the plastic “eyelets” that the bolts go through? If so ... what’s some strategies people are using? Thanks gang. I will add pictures when I’m back at the car and have the console back out.
Old Sep 14, 2019 | 05:34 AM
classicmuscle442's Avatar
Could use epoxy and fiberglass cloth to repair, fixing a four speed console I just got.
Old Sep 14, 2019 | 05:47 AM
72442455's Avatar
Joe Ralph
Never worked with either - I will you tube it and see what it takes. Thanks for the advice.
jeff in colorado
Jul 30, 2014 06:02 PM
StarfireCoupe
Mar 25, 2014 06:50 PM
garys 68
Jan 24, 2011 04:10 AM
Prophe'c
Oct 22, 2010 09:16 AM
ViceGuy
Dec 14, 2008 06:18 AM
