'69 442 headlight switch
Old Aug 4, 2014 | 06:36 AM
Eaglesfan's Avatar
Guys - how does the **** come off the headlight switch? I have the dash out of the car--cant seem to figure it out
Any guidance would be appreciated before i break it..
Thanks!
John
Old Aug 4, 2014 | 06:57 AM
Thanks!
John
Pull the **** as far out as it will go. Now press the spring-loaded button on the light switch and simultaneously pull the **** the rest of the way out.
Old Aug 4, 2014 | 11:10 AM
Eaglesfan's Avatar
Thanks Joe! I was pushing that button but probably not pulling it apart to hard.
Will retry!
Old Aug 4, 2014 | 11:28 AM
Will retry!
There's a trick to this. You must put the **** in the "headlights on" position and let go, do not pull on it at this time. Now press the button, THEN pull the **** out the rest of the way. If you pull on the **** while you press the button, it often won't release fully and you can't get the **** out.
Old Aug 4, 2014 | 03:55 PM
Eaglesfan's Avatar
Thanks -- will let you know when i get it done!!
Old Aug 8, 2014 | 05:14 AM
Eaglesfan's Avatar
worked like a charm - thanks Joe!
gwunta
Jun 22, 2024 08:59 AM
joesw31
Jul 7, 2015 03:50 PM
wisniows
Jan 27, 2014 06:45 PM
brandon reynolds
Dec 18, 2013 03:05 PM
Tom442
Jun 26, 2011 09:20 AM
