'67 4-4-2 Resto-Matching Correct Interior Colors to Exterior
Old March 30th, 2016, 09:54 AM
67442nut's Avatar
Trying to determine correct colors for the painted areas of the interior
of a '67 4-4-2 Crystal Blue (Code "D")exterior.
I've copied a list of all the blue interior colors and their codes listed in the '67 Oldsmobile Chassis manual.
I need a way to pin down which colors are correct with the Crystal Blue exterior.
I know the bottom of the dash and the tops of the doors are a medium blue satin or semi-flat finish,
Steering column and wheel are a dark blue satin or semi-flat finish and
the ends of the dash are a dark blue flat finish.
I thought, in the past, I had seen a matrix chart in some Olds manual
that matched the interior colors to their respective exterior colors.
Couldn't find it in the chassis manual or the dealer brochure.
Am I imagining this or does someone know where this chart exists?
Thanks in advance for any help.
67442nut is offline
Rocketdriver
July 8th, 2015 02:54 PM
chip-powell
June 17th, 2015 07:20 PM
orsogrigio
April 14th, 2015 02:16 PM
Indy_68_S
January 8th, 2013 06:05 AM
HiCompOlds
January 30th, 2012 05:37 PM
Quick Reply: '67 4-4-2 Resto-Matching Correct Interior Colors to Exterior
