65 Cutlass power bucket seat
Old Aug 24, 2017 | 10:09 PM
Gerald Nickels's Avatar
I bought this 65 for the interior I pulled almost all but the driver power seat. I got the two front bolt and nut off now being a power seat do I hot wire the seat or is there a quick release ?
Old Aug 25, 2017 | 07:01 AM
oldspackrat's Avatar
If you look under there one of the cables makes the seat go up and down and one makes it go back and forth. If you unscrew that cable and stick a small flat screwdriver in there you can manually move the seat up and down or back and forth to allow you access to the other bolts.
Old Aug 25, 2017 | 11:23 PM
That easy i'll see if I can get my hands under it to unscrew it. Is it on the driver side or passenger side to unscrew ? I'll guess i'll find out.
Thank You
Old Aug 26, 2017 | 07:30 AM
If this seat has the switch mounted to the side of the seat, there should be a heavy gauge main power wire coming of the motor or switch. Red or orange, usually. Simply connect this to +12V.
Old Aug 26, 2017 | 03:21 PM
I got the seat powered up but only goes up on one side and still doesn't go front to back I think its broke. I might have to cut the whole thing out on the floor. The problem now is the carpet is glued and not coming up easy. I did get the console out which I was going to do anyway. Its 107 right now too HOT to work on it now. There is a plate or cover on the bottom of the seat so not getting to the cables to do manual.
Old Sep 7, 2017 | 11:58 PM
A Olds buddy came bye today to help on the seat. We got the seat to come up in the rear and removed it. It still is working but when you send the seat to the rear the gears are bad so not a good idea to go that far back.
ros6872
Jun 8, 2023 06:00 PM
70Post
Jan 2, 2017 09:38 AM
geoff442
Nov 6, 2016 05:33 PM
69442murph
Jul 9, 2014 04:55 AM
KZ442
Apr 10, 2009 03:16 AM
