1977 cutlass rear interior panels - what years fit?
Old Dec 27, 2018 | 10:01 AM
Sandfreaks's Avatar
Just picked up a 77 442 cutlass S .
I need to replace the rear Interior Panels due to the upper portion being chipped/cracked.
This is my first Olds so Wondering what years will fit? Are the Skylark or Monte C of the same years similar enough to fit?
I'm not concerned with them being the absolute correct ones for the year more to replace them until I can find ones that are.
Thanks in advance!
Here are some pics of the interior.
Old Dec 27, 2018 | 08:15 PM
crimsoncolby's Avatar
I assume you are talking about the upper half of the two-pc plastic trims that surround the opera windows? If so, other than the "S" body style, the only other GM "A" bodies that used that design was the '74 Chevelle, '74/'75 Lemans and '74/'75 Century. And, two reasons why you can't use a '73...(1) it doesn't have the cutout for the roof seat belt retractor and (2) it won't connect properly to your '77's lower half trim. There simply are no other trims that will work with your car. These are not going to be easy to find...so, check e-Bay & Craigslist regularly if nobody on here is able to help.
Old Dec 27, 2018 | 09:06 PM
Sandfreaks's Avatar
Ok great thats the info I was looking for.
thank you!
DZAUTO
Jan 3, 2019 03:59 PM
deaddds
Hurst/Olds
Mar 16, 2017 01:19 PM
cruzer1977
Jul 29, 2016 11:53 AM
MHENDERSON
Aug 14, 2013 05:46 AM
nastywc
Sep 27, 2012 10:34 AM
