1977 cutlass rear interior panels - what years fit?
Just picked up a 77 442 cutlass S .
I need to replace the rear Interior Panels due to the upper portion being chipped/cracked.
This is my first Olds so Wondering what years will fit? Are the Skylark or Monte C of the same years similar enough to fit?
I'm not concerned with them being the absolute correct ones for the year more to replace them until I can find ones that are.
Thanks in advance!
Here are some pics of the interior.
Thanks in advance!
I assume you are talking about the upper half of the two-pc plastic trims that surround the opera windows? If so, other than the "S" body style, the only other GM "A" bodies that used that design was the '74 Chevelle, '74/'75 Lemans and '74/'75 Century. And, two reasons why you can't use a '73...(1) it doesn't have the cutout for the roof seat belt retractor and (2) it won't connect properly to your '77's lower half trim. There simply are no other trims that will work with your car. These are not going to be easy to find...so, check e-Bay & Craigslist regularly if nobody on here is able to help.
