1967 442 sail panels
Old Feb 10, 2022 | 06:05 AM
Bills67's Avatar
I started to do my headliner and remove my sail panels from the car and there is another fiber backer board behind them and they are held on by metal tabs! does this board need to be replaced and if so what should I use for material? (buy more sail panel board?) and cut it to fit? or do they sell them and where?
Old Feb 10, 2022 | 09:08 AM
oldolds88's Avatar
upholstery store will have the correct board,then its cut and paste. exactly what im going to do on my 65
Old Feb 10, 2022 | 10:52 AM
RAMBOW's Avatar
Ben
Is it a firm board like the sail panel or is it soft to the touch? Usually under the sail panels there will be a soft insulation "pad" glued to the inner roof structure- it always crumbles when you touch it or try to remove it.
Restoration catalogs will likely have precut replacements- but you could replicate it with a piece of felt, trunk liner or something similar. Its really just to prevent rattling.
Many leave them out when doing sails or headliners, but it was there for a reason so its good practice to put something back in.
-Ben
Old Feb 10, 2022 | 11:09 AM
Oldsmaniac's Avatar
If it were me I would try and use Velcro possibly to attach?
Old Feb 11, 2022 | 10:19 AM
Bills67's Avatar
do you have a name and number for an upholstery shop?
Bills67
Jan 8, 2022 12:36 PM
hackmansr
Feb 20, 2016 06:05 AM
Olds442redberet
Feb 24, 2014 04:23 AM
Olds442redberet
Jan 13, 2014 11:37 AM
rennoc442
Oct 30, 2010 08:54 AM
