Suitable Replacement Radiator on my 84' ?
Old Aug 8, 2012 | 10:48 AM
HurstLightning84's Avatar
W40 Kid
I'm working on replacing the radiator in my 84', and I'm not having a very fun time finding one. Even more so, one that's pref made in North America. Any body have any recommendations?
Old Aug 8, 2012 | 03:46 PM
ThePackRat's Avatar
Big Daddy No Bucks
I'd go with an F-Body aluminum radiator.
It will require some tweaking to the trans cooler lines (slight bending by hand to line them up) & plugging off one hose connection that does not get used.
Other than that ... it drops right in.
Benefits are a cooler running engine.
Application I used years ago to get the right one at the parts counter ... was a 1989 F-Body w/a 350.
I think it's a Modine 951.
Old Aug 17, 2012 | 10:22 AM
CaptOharry's Avatar
Can't you have it Recored?
Old Aug 17, 2012 | 11:12 AM
1970cs's Avatar
Lansing built
X2 Ryan take it to either Corbin radiator in Lansing or Austin Radiator in Mason, Find how many fins/inch thats on yours and maybe double, the fins per inch.
Pat
Old Aug 17, 2012 | 02:33 PM
Mikes65's Avatar
I found a Griffin aluminum 4 core for my 65 which was identical to the original--just aluminum and more cores-the tanks are the same. Only gets to 185 at idle on a 100 degree day. I did add a shroud also.
Old Aug 24, 2012 | 09:32 AM
W40 Kid
I actually found one from a parts store here in town that did some digging for me. And found a exact replica of what was in there. Surprisingly a lot are going to the hard plastic tanks now, which I never thought of being an issue, so the one I have you can tell has been sitting on the shelf for quite some time, but still has the brass tanks and is a 3 core like the original. Made a world of difference! I felt it was better to just replace the original rather than getting it re-cored cause it had been repaired and re welded a couple different places at a few different times, and started to show signs of future issues.
SteveL442
Aug 19, 2010 02:59 PM
poorboy_616
May 18, 2010 08:45 PM
poorboy_616
May 17, 2010 09:54 PM
super88
Jul 19, 2008 01:46 PM
HAFROD
Mar 20, 2008 04:45 PM
