79 H/O need help chasing a wire down.
Old Sep 3, 2015 | 10:21 AM
pav8427's Avatar
My 79 H/O needed a new headlight wiring harness when I got it. I was able to get one for a 78 Regal. With a little splicing I was able to get all the lights to work. When I swapped out the harness I found a extra wire on the H/O harness that was cut and not sure where it went. Could anyone help me chase it down?
It is brown and has a factory spade connecter about 6-8 inches from the firewall plug. That is paired with another brown and blue wire from the plug.
Thanks Doug
Old Sep 3, 2015 | 04:56 PM
geardoc66's Avatar
Sounds like the underhood lamp connector. Does it have power when the running lights are turned on?
Old Sep 3, 2015 | 05:28 PM
pav8427's Avatar
Can you say DUH. I have been looking at this thing for almost 2 years and didnt even relize there wasnt a wire to it. Looks like it just pulled right out of the connector at the lamp.
I never did like chasin electrical gremlins.
Old Sep 19, 2015 | 05:22 AM
BlueCalais79's Avatar
Yep, I was about to make that same suggestion on where the wire goes, I followed mine to it as well.
Well done, looks like you've got it solved
72cuttys
Jul 14, 2014 08:00 AM
1970cs
May 26, 2014 05:40 PM
Macadoo
Nov 24, 2013 07:24 AM
StarGeneral
Sep 30, 2012 10:29 AM
w-30dreamin
Apr 6, 2011 10:29 AM
