Headlight switch from dash removal ?
Old Jan 17, 2013 | 08:14 AM
Houston_t's Avatar
How the heck do you remove the headlight switch from the dash ?
Old Jan 17, 2013 | 08:41 AM
MX442's Avatar
With a BFH.
What is it on?
The last one I tried to remove, it was so corroded that the **** would not pull off.
Old Jan 17, 2013 | 08:46 AM
Houston_t's Avatar
71 cutlass, tried for about 30 mins last night and can't get the **** off
Old Jan 17, 2013 | 09:52 AM
MX442's Avatar
Haha, if you're not signed in, "****" is a censored word on this forum.
Old Jan 17, 2013 | 10:01 AM
Octania's Avatar
The **** is supposed to stay on the shaft
Do you not have at least a Chilton manual?
what year?
for '68 and similar:
disco battery
pull out **** all the way
find button on side of switch way up back there. On metal side opposite wires.
Press button
pull ****/shaft all the way out of the hole
...[I see why that is censored now]
Now the bezel or escucheon is a nut that holds the switch in. Best way w/o muffing it up, if real tool is not available [naughty again]... use your fingers [oy vey] on the nut... wiggle the switch cw and anti-cw from the back meanwhile, and it should gradually unscrew.
Mind you I did have ONE unit where the button trick failed. Aftermarket POS switch, would NOT let go. I thought it was going to break the dash I was pulling so hard. Had to cut the shaft off. I put a real GM switch back in.
Old Jan 17, 2013 | 10:22 AM
lshlsh2's Avatar
71 cutlass convertible
Take the gas gauge out, I found it easier to get at the switch through that hole than up an under the dash. It is alot more fun if you have A/C, like I do.
Larry
Old Jan 17, 2013 | 11:12 AM
MX442's Avatar
Chris, you crack me up. Who knew you just had to pull the **** and use your fingers to wiggle the nut on the shaft. I guess that's why I couldn't get the last **** off. (it was a 68)
Old Jan 17, 2013 | 08:26 PM
Gary's 2 442-S's Avatar
Gary
Larry
I agree with this. much easier if you take the gauge out. That is what I did. also its a pain in the rear trying to get the shaft back in.
gwunta
Jun 22, 2024 08:59 AM
Mak
Dec 29, 2012 04:46 PM
medri
Apr 29, 2012 05:33 PM
71supreme
Sep 22, 2010 05:28 PM
jaunty75
Jul 31, 2009 04:19 PM
