72 convertible resto
Hi everyone just a couple question about restoring my 72 cutlass supreme convertible .The car needs a ton of work the upside is the car sat for25years and with a new battery and shot of starting fluid it's running like a champ on the 25 year old gas.my question is where to start underbody and frame ? And work up from there and should interior and new top come after new paint? Thanks for any input
Pis are not too bad . I believe they have to be no bigger then 800 x 600 to which you can shrink them online , and then while your posting click on manage attachments and upload them from your desktop or whatever ... after you close the upload file box out , you can click on each photo listed below manage attachments and copy them to the thread to make them bigger . There is a way to make them even larger when you post , but I forgot how
Im working on getting some pics out .Im hoping for a nice frame on restoration over a period of a couple years in the range of 10 to 15 thousand the car needs several patch panels and considerable body work which ill leave to the pros .all ive done so far is get it running and new master cylinder and brake lines so i can stop it
the frame is in great shape with only surface rust floorboards and trunk need only minor work and the top does go up and down and i recently learned it has a posi trac rearend ,so there are some positives to this old girl
RustyTrusty72
Oct 16, 2012 08:25 AM
