68 442 fuel pump question
Old Jul 25, 2010 | 12:30 PM
JBrooks's Avatar
Does anyone have a recommended source for the correct mechanical fuel pump for a 1968 442? I will need a model with three ports on the top of the pump.
I have managed to buy the wrong pump and would like advice on a source to purchase the correct pump.
Thanks for any help.
Jim
Old Jul 27, 2010 | 09:40 AM
Jim
When you say "correct" do you mean "concourse restoration correct" or simply functionally correct? Rockauto (and most parts stores) sell a functionally correct three-port mechanical pump. Here's Airtex P/N 40523:
Old Jul 31, 2010 | 07:19 PM
JBrooks's Avatar
Thank you, Joe.
I purchased one from the Parts Bin that looks identical to what I removed. I am hoping it will work.
Jim
Old Jul 31, 2010 | 07:46 PM
rocketraider's Avatar
Oldsdruid
When it comes to fuel pumps, try to get one that can handle modern gasoline. I've come to the conclusion it is utterly stupid to pay megabucks for an NOS pump when the odds are pretty good it will self destruct as soon as modern gasoline hits the diaphram.
Old Aug 13, 2010 | 10:02 PM
JBrooks's Avatar
It took me a little while to install, but the fuel pump from the Parts Bin looked exactly like the pump I removed and seems to be working perfectly. I did not have to rebend the fuel line, for which I am very grateful.
The only concern was that the pump was labeled as for a 455 engine in '68. My engine is a 400.
Jim
Old Aug 14, 2010 | 05:56 PM
Jim
Not an issue.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
