Changing Light Switch in Dash
Before I break my back tackling this, has anyone come up with a better way of swapping this out? Looking for tips and tricks from those that have found an "easier" approach to changing the light switch in the dash on a '70.
Get a couple LED lights, the small ones with the magnet base.
Pull the drivers seat (or bench) and put a moving blanket on the floor and on the back seat (prevent scuffs, or remove it too.).
Relax and take your time.
I used a combination of access, partly thru the fuel gauge hole and from underneath - the top mounted plug was a b!@%# to remove from what I believe was still the original switch that was still in my car when I got it in 2016, I think I recall having turned the switch sideways to remove mine. I didn't have to remove the seat.
I dabbed the contacts of the replacement switch with grease when I installed it along with my new wiring harness back then, assuming that would help with removing the plug if there was a next time needed for replacement again.
