Changing Light Switch in Dash
Old Jun 2, 2026 | 04:59 PM
WTHIRTY1's Avatar
Escape From The Ordinary
Before I break my back tackling this, has anyone come up with a better way of swapping this out? Looking for tips and tricks from those that have found an "easier" approach to changing the light switch in the dash on a '70.
Old Jun 2, 2026 | 07:38 PM
tru-blue 442's Avatar
Old School Olds
Following. I need to do the same. I was thinking about pulling out the rally pod some to see if that could make a little more room.
Old Jun 2, 2026 | 09:32 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Get a couple LED lights, the small ones with the magnet base.
Pull the drivers seat (or bench) and put a moving blanket on the floor and on the back seat (prevent scuffs, or remove it too.).
Relax and take your time.
Old Jun 6, 2026 | 04:06 PM
Jungle Cat's Avatar
The toughest thing is pulling and replacing the wire plugs. There is no room in there.
Old Jun 7, 2026 | 08:07 PM
70sgeek's Avatar
'72 Cutlass ragtop
I used a combination of access, partly thru the fuel gauge hole and from underneath - the top mounted plug was a b!@%# to remove from what I believe was still the original switch that was still in my car when I got it in 2016, I think I recall having turned the switch sideways to remove mine. I didn't have to remove the seat.
I dabbed the contacts of the replacement switch with grease when I installed it along with my new wiring harness back then, assuming that would help with removing the plug if there was a next time needed for replacement again.
radiofellow50
Oct 1, 2024 08:32 AM
Chuxter
Mar 20, 2024 09:48 AM
72455
Oct 1, 2020 07:10 PM
53oldsmobile
Jul 12, 2017 05:58 PM
jonstringer
Mar 13, 2009 07:00 AM
