Fan Clutch
Old Jan 21, 2021 | 03:10 PM
tnswt's Avatar
'70 4-Speed W Machine
Fan Clutch
I have a used fan clutch (4949861 - code OR) that I purchased as a working unit. I understand these units are sealed with oil. If that is the case then I should be able to submerge the unit in Evaporust to soak it clean without damage to it?
Old Jan 21, 2021 | 08:10 PM
70Post's Avatar
I wouldn't do that. Degrease it by hand, sand the front steel part to remove any corrosion, etc and paint or do whatever you want finish-wise. These can be rebuilt/restored but it's not a low cost operation.
Old Jan 22, 2021 | 10:49 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Like Patton said, I wouldn't submerge that. Check my resto thread, I have details around the rebuilding process of the fan clutch. There's a Corvette shop that does a superb job at rebuilding fan clutches. What's the julian date on the fan clutch you're showing?
Old Jan 22, 2021 | 12:02 PM
Stefano's Avatar
I WOULD use evaporust as you stated, just that I would watch and see what happens and only leave it in for an hour or two. I have not seen short term evaporust hurt rubber seals. No liability expressed or implied.
Old Jan 31, 2021 | 04:08 PM
Jungle Cat's Avatar
Those had a gold zinc finish on the front that you will never get back once it’s sanded. They should always be stored face down as well. No one will see it when installed anyway.
Old Jan 31, 2021 | 07:01 PM
Schurkey's Avatar
They go years at a time "sideways" when installed on an engine. Why would they need to be stored face-down?
Old Feb 1, 2021 | 06:42 AM
tnswt's Avatar
I was too chicken to install the used fan clutch even after I cleaned it because all I could think of was the possibility of it flying off and going through my original radiator, or worse, flying off and striking me in the temple. The scenarios I describe may only be something I conjured up in my mind, but since the clutch was used, I had no real idea of its true condition.
Currently the fan clutch is down at Kirkconnell Corvettes going through his rebuild process. I know it will cost a few coins, but considering the alternatives, I thought it was best. Turnaround is expected to run 2-3 weeks.
Thanks everyone for the feedback.
Old Feb 1, 2021 | 11:42 AM
Jungle Cat's Avatar
I’m not an engineer but it’s often printed on the box to store face down.
Old Feb 1, 2021 | 11:45 AM
Jungle Cat's Avatar
In this case store face up is the flange side up. It’s an NOS clutch
Old Feb 23, 2021 | 03:49 PM
tnswt's Avatar
As a follow up as to how to store a fan clutch, the following was printed at the bottom of my rebuild fan clutch receipt that I received from Dan Kirkconnell Corvette Service. This outfit rebuilt the OR code Olds fan clutch for me. I guess it does not matter, horizontal or vertical, both are proper.
Note:Although some fan clutch units state “This side up”,
We recommend storing units on their side (as in the normal application), which will help the oil to remain distributed evenly within the unit.
Cutlass71s
Sep 5, 2022 05:08 AM
My2nd 69 442
Jan 17, 2021 06:11 PM
jpc647
Dec 16, 2016 06:21 AM
toymobile
Jul 7, 2015 06:55 AM
oldsonharmont
Feb 24, 2010 12:46 PM
