Where would I find the radiator code?🤔🤔🤔
Old Oct 28, 2020 | 04:49 AM
72455's Avatar
1972 U code Supreme
Hey all I'm trying to verify if my '72 U code Supreme has the original radiator. Y72, A/C, automatic with a tranny cooler. Here's the chart from the assembly manual, but where would I find the code on the radiator?
Thanks,
Dave
Old Oct 28, 2020 | 05:14 AM
69HO43's Avatar
Typically I've seen the relief-stamped code on a metal tag on the passenger side, attached to where the tank mounts to the fins a few inches down from the top on the back side of the radiator. The tag is just clipped on it, so it may be missing. They should also have the Harrison logo stamped on it somewhere. I could be mis-remembering that.
Not sure if they mounted them anywhere else.
Old Oct 28, 2020 | 08:24 PM
2blu442's Avatar
There is a code pressed into the tanks too. There will be a two letter code for the application. Then a date code. If someone else doesn't post it I'll get some photos of an example this weekend.
John
Old Oct 28, 2020 | 08:26 PM
2blu442's Avatar
Ah! Here's a thread on one I sold a while back. It doesn't have the tag but has pictures of the code stamped into the tanks.
https://classicoldsmobile.com/forums...y-sold-143321/
Old Oct 29, 2020 | 06:55 AM
Dave, go to this link for my 72 radiator.
The re-core turned out perfect and there's information in the thread about the tanks and tag.
bwayco
Apr 5, 2018 08:16 PM
ROCKET VAPOR
May 23, 2014 08:15 AM
Olds1971
Mar 31, 2014 01:18 PM
ScottoW31
Dec 4, 2013 08:31 PM
ctreutel
Oct 27, 2013 01:54 PM
