Hey all I'm trying to verify if my '72 U code Supreme has the original radiator. Y72, A/C, automatic with a tranny cooler. Here's the chart from the assembly manual, but where would I find the code on the radiator?
Typically I've seen the relief-stamped code on a metal tag on the passenger side, attached to where the tank mounts to the fins a few inches down from the top on the back side of the radiator. The tag is just clipped on it, so it may be missing. They should also have the Harrison logo stamped on it somewhere. I could be mis-remembering that.
There is a code pressed into the tanks too. There will be a two letter code for the application. Then a date code. If someone else doesn't post it I'll get some photos of an example this weekend.
