72 Cutlass fuel tank
Old June 15th, 2020, 04:49 PM
NorthBay72supreme's Avatar
I am in the process of replacing a faulty fuel sending unit and just got stuck removing the straps of the gas tank.
Apologies for asking a stupid question, but how do I remove the bolts? At the halfway point, I can't turn the bolt and the nut mounted on top of the slide nut seems frozen. I sprayed it with a healthy dose of lubricant but don't believe that's the problem. Incidentally, the assembly manual doesn't show a nut on the other side of the slide nut.
SOS. Thanks guys.
NorthBay72supreme is offline
Old June 15th, 2020, 04:56 PM
v8al's Avatar
Sometimes the cage nut breaks at the top and just spins. If that's the case just put vice grips on the remains of the cage and back out the bolt. If the bolt won't turn at all then either keep soaking the nut or be prepared to cut it off. You can also try an impact gun - sometimes the hammering will free up the nut.
v8al is offline
Old June 15th, 2020, 05:57 PM
The threads above the nut are probably caked with dirt, rust, etc that makes the bolt bind when moving through the nut. If that is the case, do back and forth tigntening / loosening or try to clean the threads with a brush, spray solvent, etc.
Fun71 is offline
Old June 15th, 2020, 06:27 PM
Both slide nuts were in fact cracked. Got them off though finally.
Old June 15th, 2020, 06:28 PM
I I was able to get both of them off by pretty much spring PB blaster while using my impact gun to tighten and loosen. That process took so damn long but they're off.
Old June 15th, 2020, 07:55 PM
Yeah, I recall cursing how long those bolts were when removing the tank but then realizing why they were that long when reinstalling the tank.
Fun71 is offline
Old June 15th, 2022, 05:28 PM
tv442's Avatar
Bolts
I am looking for original gas tank bolts for my 71?
Thanks, Tim
tv442 is offline
teamwieland
September 26th, 2019 10:55 AM
Joffroi
23
April 25th, 2014 10:43 AM
OldsCutlass70
May 20th, 2013 04:42 PM
71Oldsmobile
May 5th, 2012 07:08 AM
krissiibabii
September 13th, 2010 05:38 PM
Quick Reply: 72 Cutlass fuel tank
