Help with W-25 Hood lock bracket
Old Jan 22, 2020 | 05:04 PM
Brians1's Avatar
Need some clarification, just purchased my W-25 hood from Stinger Fiberglass (looks great BTW) and I also brought the needed hood latches/locks/springs needed to complete the install on my non w-25 car.
Just did a test fit of the brackets for the hood lock...I know its in the right spot due to the indentations but is this overlap and lack of a 3rd hole expected, I didn’t see a different cross brace/radiator support for Non W-25 cars....
Here is the Hood as well
Old Jan 22, 2020 | 07:50 PM
70Post's Avatar
That is all just fine and correct. Just put your own hole in the support for the third bolt/nut.
Just for grins.....took this pic of the "third hole" side of an original hood pin bracket. Shows the height but not ULTRA exact for comparison purposes as you'd have to have a caliper in the same spot. I swear your bracket appears to be slightly taller but it might just be the pics, etc.
Old Jan 23, 2020 | 02:32 AM
Brians1's Avatar
Thank you , I just needed the sanity check
olds 307 and 403
May 3, 2018 01:12 PM
pencetaylor
Nov 13, 2015 08:09 PM
Four Four Tony
Oct 29, 2015 06:14 PM
cdrod
Body work
Jun 30, 2014 10:38 AM
FIJIBLUE72
May 21, 2009 04:14 PM
