1969 cutlass splash shield installation advice
Old Jul 10, 2017 | 06:24 PM
stix's Avatar
The old splash shields were installed with staples and the reproductions shields I have also came with staples but Im not sure how to attach the shields to the fenders since I dont have the proper staple gun. I wasnt able to pull much info off the forum regarding this. How are the rest of you guys attaching them to the fenders. Thanks!
Old Jul 11, 2017 | 05:44 AM
You don't need a staple gun. You can use the old shields as a template to locate holes in the new ones with an awl. Then line up the shields insert the staples and bend the lgs over with a pliers, tap flat with a hammer.
Old Jul 11, 2017 | 06:02 AM
The factory usually did a crappy job with the staple placements, something I didn't like. I used a very small diameter drill bit and drilled the splash shield and inner liner in place to match the new staples. Then insert staples and flatten with hammer and dolly. I did mine when the liners were out of the car, same as doing the air dam.
Old Jul 11, 2017 | 06:28 AM
rcorrigan5's Avatar
Randy C.
I did what Allan R did for both of my Oldsmobiles. It was somewhat tedious but it works!
Randy C.
'68 4-4-2 convertible
'69 4-4-2 convertible
Old Jul 12, 2017 | 03:49 PM
stix's Avatar
Thanks for the replys, I have done the rivet method, yes it was tedious but I really never liked how it looked but that was on a mostly "correct" camaro, this car has much custom done to it so correct is not as importent this time, I was hoping there was an easy way to attach them but no project is ever easy!!
BeenThere
Aug 17, 2018 01:17 PM
AJFink
Mar 20, 2017 10:46 AM
Jandk
Ninety-Eight
Feb 15, 2016 08:58 AM
sunsetlimited
Nov 4, 2011 11:32 AM
oldzy
Brakes/Hydraulic Systems
Oct 2, 2010 06:09 PM
