350 Starter Heat shield installation
I am putting things back to stock, when I bought the car it did not have the heat shield. I have the assembly manual and what is shown and what I have is different. Here are pictures with and without the heat shield installed. What do I have to make or get to make this right. This is a 1972 cutlass supreme 2 door coupe.
I ran into the same problem. I modified the hole in the shield to allow a large gear/hose clamp to slide through and wrapped it around the starter. Tighten everything up and you should be good. You can paint a little black on the clamp and you can barely see it.
Mike
Mike
Can you return the starter for a different one? Maybe they will have one with the threaded hole. Be careful if you put a bolt in the hole that isn't the correct stud. If it goes in too deep it will ground out the field winding. I have a rebuilt starter for sale with the hole if you want one and can't find one.
Bens71442
January 3rd, 2006 03:33 PM
